is the LS6 block better for buildup?
Old Jul 28, 2004 | 09:36 PM
Zapata's Avatar
Default is the LS6 block better for buildup?
i'll be starting on a 383 stroker as soon as i find a block, i've been told that the LS6 block is "better" for more power, but is it going to be a difference that i'll see over doing the same build with an LS1 block. thanks
Old Jul 28, 2004 | 10:55 PM
jrp's Avatar
jrp
SN95 Director
the ls1 block is structurally stronger.
Old Jul 28, 2004 | 11:16 PM
Zapata's Avatar
but as far as power....strength isn't an issue i would think since it's going to be an NA motor.
Old Jul 28, 2004 | 11:33 PM
FASTONE's Avatar
How would an LS6 block make more power then a LS1 block,with the same bore???
Old Jul 28, 2004 | 11:38 PM
camaro98z28's Avatar
The LS6 was made from the Gods LMAO
Old Jul 29, 2004 | 12:35 AM
jrp's Avatar
jrp
SN95 Director
there is no power difference so thats why you should pick the block on strength. the ls6 block does have the better bay to bay breathing though.
Old Jul 29, 2004 | 12:49 AM
Ben R's Avatar
There will be no power increase/decrease based on your decision to go with an LS1 or an LS6 block.
The LS1 block is stronger than the LS6 block, however. If you talk to a machinist who has experience with LS1's and LS6's they almost always prefer to use use LS1 blocks.
FWIW, Steve at Race Engine Development (Sponser) was telling me that the best block to re-sleeve is an LS1 block, especially if any type of nitrous/blower/supercharger is going to be used.
Old Jul 29, 2004 | 12:50 AM
FASTONE's Avatar
I thought that was about the only defference jrp,still funny!
Old Jul 29, 2004 | 02:01 AM
PREDATOR-Z's Avatar
Well the LS6 also has oiling galley on the crank journals that the ls1 doesn't have.
I wouldn't sleeve an LS6. IMO not worth the extra cash.
Also it is much wiser to use a seasonned block instead of a "new" one.
