eBay reman heads
I'm looking for something that doesn't break the budget but that has at least had someone go through them. Anything local seems to cost significantly more money.
Thanks!
Thanks!
My self, I wouldnt have used them. The valve tips looked like they were surfaced on a bench grinder. The valve job was ok. How ever, I did not check all the worked preformed. Some of these seller accept anything back as a core and will try to re-use as much as possible.
I would rather use a local place where I can hold them accountable if something is not done correctly.
Thanks!
Stem to guide clearance was correct, spring heights were correct, three angle valve job that sealed, nice finish on the decks.
The only gripe was I didn’t care for the paint job and one exhaust port had some carbon left that didn’t clean up. The heads were packaged well and sent out the day of purchase.
