.600" lift for daily driver?
Old Oct 4, 2025 | 11:58 AM
Abs's Avatar
Abs
Originally Posted by gametech
The ls9 cam is a terrible choice for almost anything. The only reason it is acceptable for the factory ls9 is because the complete lack of low end torque is made up for by having a big PD blower on the engine. Without instant off-idle boost available, that cam will have the lowest torque of almost any option available.
agreed. For a turbo it would be awful down low. Also bad NA. Only good with a supercharger.
Old Oct 4, 2025 | 04:28 PM
Full Power's Avatar
Originally Posted by Abs
. I tend to think that using the minimum required lift spring would be best in this scenario, like the pac 1218 spring, which had 130lbs of seat pressure and 310lbs of pressure at .600 lift.
I probably wouldn't use a .600 lift cam unless you were swapping lifters. The stock lifters are often close to if not older than 20 years, and a .550 lift cam would treat them better.
. It is a fact that these particular LQ4 lifters are 20 years old. I will be using new lifters on this motor. Concerning the valve spring choice: If I DO talk myself into a .600" lift short duration cam, is it you opinion that the PAC1218 listed MAX lift.600" would be the best choice, and NOT PAC 1219?
... Stock rockers planned, upgrayyd Pushrods to .080" wall. " Think it'll live? "
Old Oct 5, 2025 | 10:34 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Just to add a new twist to the discussion. In a first as far as I am aware of, it seems that there may be a bad batch of PAC springs floating around recently. There has been some discussion on yellowbullet about it. They have always been my trusted go-to spring source.
edit-- Both threads I saw on the subject were regarding the same valve spring, with no part numbers listed and allegedly came on heads that were already assembled. I doubt the person reporting the issue could even say for sure they were legit PAC springs. I hate to be the guy spreading unverified rumors.
Old Oct 6, 2025 | 01:29 AM
Full Power's Avatar
"bad batch of PAC "
Uh-Oh. Reports limited to a particular series? Single or dual springs affected ?
1218 or 1219 mentioned ?
Do we "know" who makes the SUMMIT branded BeeHives?
Old Oct 6, 2025 | 02:42 PM
grinder11's Avatar
@TurboBuick6 Say it ain't so, Matt!!!!!
Old Oct 6, 2025 | 02:56 PM
TurboBuick6's Avatar
No idea, hearing of this today for the first time.
Old Oct 6, 2025 | 03:06 PM
grinder11's Avatar
It sucks if it's only a rumor. Because if it is, it was probably started by either a disgruntled customer or a competitor, or both. I looped you in so you could hear about it as soon as I did, which was less than 1/2 hour ago. I run nothing but PAC, and have no intentions of ever running anything else. There's only one other valvespring I've ever run that compares to my PACs for reliability, and those were s set of 16 Comp 26921 dual springs I ran in 2005. Never an issue with them, either. But I prefer PAC.....
Old Oct 6, 2025 | 07:23 PM
gametech's Avatar
Please see edit to my post on the PAC subject. Likely a rumor.
Old Oct 6, 2025 | 09:00 PM
1FastBrick's Avatar
It also had to pass emission standards...
