Testing stock oil filter bypass
Old Sep 27, 2025 | 11:20 PM
Walravenseth's Avatar
Default Testing stock oil filter bypass
Quick couple questions for you guys
I'm going to do the first oil change on a truck with an lq9 that I got, and I saw that the oil filter bypass is built into the pan rather than the filter. I was wondering if there is any way to test it other than just a visual inspection/seeing if it moves. I have no reason to think it's bad or anything like that so I don't want to get crazy trying to replace it, just am curious and want to learn a thing or two.
Thanks!
Seth
Old Sep 28, 2025 | 03:38 PM
dixiebandit69's Avatar
If it's an LQ9, it shouldn't have a bypass valve in the pan; that's only on Gen IV engines.
IF you, or someone else swapped a Gen IV pan on there, I wouldn't even bother with testing the valve, I would just delete it. Get an appropriately sized bolt, and put that in it's place.
Old Sep 28, 2025 | 04:42 PM
the_merv's Avatar
Veteran: Air Force
I'd like to see a pic of what is being called the "bypass"..
Old Sep 28, 2025 | 05:11 PM
Bypass is in the pan on gen4 engines, directly above the filter. I buy the delete kits from Summit Racing. Here’s a link…
https://www.summitracing.com/parts/ew1-571997
Old Sep 28, 2025 | 05:40 PM
I was assuming since the pf46 it calls for doesn't have a bypass in it, the bypass would be that boss right next to where the filter screws on the oil pan. I believe it would like this.
Old Sep 28, 2025 | 06:36 PM
If you're talking about the two-bolt flange right above the oil filter, there is no bypass in there.
Also, use a bigger oil filter than that one; that short oil filter is intended for the shallow sump F-body pans. You have the clearance for it.
Old Sep 28, 2025 | 06:50 PM
Yeah I intend to use a pf61 sized filter. Bellow I have a better picture of what i talking about, but it is plugged in that picture. Here is the link to where I got that pic.
