High mileage LS1 questions
I have a 1998 z/28. Mods in signature. It has 223k miles and has been sitting since 2019. It needs front and rear seals and oil pan and valve cover gaskets. I'm looking for some advice on some "while we're in there items." The engine is quiet, runs strong and has good oil pressure. The car is just a fun no worries drag car that I want to slowly make faster. If I wanted to I could swap in a built engine and shoot for 10's but I'd rather slowly cut the time step by step.
1) I'm planning on swapping to headers, collector extensions, race bullets and dumps to keep it light and easy to work on.
2) Since the oil pan is coming off, I'm planning to change the oil pump and update to a better oil pan with better baffling and windage. I don't know which one yet.
3) Timing chain will get replaced when the front cover comes off.
Questions:
1) Should I change the valve springs and push rods while the valve covers are off?
2) I'm afraid to change the cam because the bearings are likely worn but should I just go for it while it's apart?
Thoughts appreciated.
I suspect my challenge will be getting the car to hook efficiently. I'll have to learn how to set up the suspension -- torque arm and lca settings, shock settings, tire pressure, etc. to get it to hook right and go straight. I know there are cars with a LOT more power that are hooking on 275 MT/SS.
Thanks!
