Best heads for 500hp?
I'm not the only one who has done it. The used cam in my combo did it in another combo. And by today's standard it's not that big. 23x 24x range like everyone in this thread is talking.
Through a 9" and exhaust out the back. Didn't even pull the air cleaner.....that typically makes more......dumps would likely make more. E85 would make more . Bypass the ps would make more.
Realistically 600whp out of a 5.7 isn't out of the question.
The record for the fastest sbe 5.7 is 9.2......it likely made more than mine.
My 5.7 isn't really sbe tho. Although not far from it. Basic rebuild with gen4 rods and off the return shelf mahle pistons. Stock crank ofcourse.
As I always said. If my bolt on ls6 can make 451whp 423wtq and your average h/c ls1 can't make atleast that and realistically more......then you did it wrong. Not the engine......but you.
Most on here would be wondering what cam it needed......or the greatest newest baddest heads to put on it.......while still not trapping what stock **** did🤣🤣
Hell, mine with the fast 102, ls2 tb, tea stage 2 243s still made 470/420 with less than stock compression. If I would have ran a thinner gasket, flycut the pistons and really honed in on that combo, it could have made 500 easily. I did really not much work to make another 35-40 wheel out of it going to the tfs 220s, hi ram and johnsons with a thinner gasket. The most work was cutting the hood haha
I recently bought a 2010 Camaro from the Camaro5 forums, and it is 530whp NA. It has a GPI Max Performance package on it, which is small bore LS7 heads, LS7 manifold, and camshaft 238/256 .648"/.639" 113+4. Also has other supporting mods. Trying to re-create this setup (just the heads/cam/intake/lifters package) is about $7k. Driving it around town is fine, but if you get stuck in stop and go traffic it's not very fun - it is a M6 with a twin disk clutch. It's driveable, but doing constant starts and not getting to release the clutch fully before having to stop again, over and over, is not very fun and makes me worry about overheating the brand new clutch I just put in. As a side note, it has 20k miles on the package, and I currently have it down for changing out the lifters, one of the Johnson 2110R lifters went bad already - high lift cams require high pressure springs which put extra load on the entire valve train.
Getting the Cam, Heads, and Intake all to work together is the most important thing when trying to make power NA.
Then wonder why their combo is slow and pick a bigger cam to fix it.
Btw....we made as much as 470whp 470wtq with a bolt on ls3. That was in a 5gen. With a bolt on ls3 in a c6 we went 10.5@132......not gutted and through the oe npp mufflers. I bet if someone was serious a bolt on ls3 in a c6 could touch the 9s.
Today that same combo with some minor changes could easily make over 500whp. We had a ls6 intake on it......because back then that was all that was really available. I bet a ported msd would have picked it up 30whp. Had no ewp so there's another 10 especially with the belt mod I do....maybe even a little more. The pistons were poop....heavy *** je with thick rings. A set of mahle power pack pistons are way better. It had poopy Mac mid length headers and some home made exhaust. Se headers and td x would be a massive improvement.....which is what's on my car now except the headers are kooks. No crank scraper and pump gas......that's why i said one can get 500whp out of a 5.7 without leaving the gmpp parts catalog.
It seems many of these guys are stuck thinking they did the ultimate best job and picked all the right **** without thinking about what they actually did or evolving with the times.........then they cop a attitude.
They stuck at 6500 rpm for some reason too. My bolt on ls6 got turned up to 7200......this 5.7 turns 7800. No crazy valvesprings on it. Just some thought put into it.
My comment wasn't aimed at HioSSilver. It's more about people who think inflated dyno numbers mean there car is faster than someone's car that puts down lower numbers. Through the years I've seen people claim a cam only 5.7 puts down 450 hp. Maybe their dyno slip says so or maybe they are just full of it. It's amusing nontheless.
I'm not really aware of a lot of people running over 11:1 compression on a daily driver type of 4th gen. Sure cranking up the compression can make power but is it going to hurt the engine long term in hot and humid conditions?
It's funny you would do that tho.....I went 131.3 and can clearly see how he went 135.......I guess you either know or you call bs.
You call bs because you don’t know.
I just cannot see a 3.898 bore utilizing cathedral heads originally designed for the smaller bore making more horespower and torque than a 4.125 or larger bore using LS3 or LS7 heads with a similar camshaft.
I know we won't get any factual evidence and that's okay!
I had a 2000 Camaro, 5.7 flat tops, TFS 215s out of the box, LS2 intake, auto T400 trans, 4.10 9", light, and it went 10.92@123 and it was actually set up for nitrous. It made 42x rwhp unlocked on a Dynojet. This was 18 years ago.
My car made 408 rwhp with a 227/234 cam, ported 243 10.5:1 compression, M6, DLS2 intake. I probably picked up a couple HP when I upgraded the exhaust. Open the cutout and I get maybe another 10 or so.
