ls2 crankshaft on ls1
Yea maybe they are accounting for people being lazy and not wanting to jump through all the hoops to get onto a Forum. Not a bad way to sift the lazy out IMO..
The 24X will have a two-piece Reluctor, it's two pieces of sheet metal welded together for the different pattern.
The 58X Reluctor is one piece with even Teeth all the way around it with one spot about 1" long with no Teeth, it's just blank.
If you have the Engine in the car you would have to pull the Oil Pan or put a Camera in the Crank Sensor hole to see it.
But then you say this..
Bunch of us have been talking about the LS2 having both a 24X or 58X Tooth Reluctor Crank so my question to you is have you checked to see what exact one you have?
If the previous person went that far into the Engine there is a possibility other things are incorrect. The Camshaft Timing Gears could be not timed correctly. If it's an aftermarket Cam the car could not be tuned right. No reason to put a LS2 Crankshaft into that Engine besides it's the same 3.622 Stroke, maybe they did not know about the 24X and 58X Reluctor difference.
Obviously we aren't looking at the car with you but until things are known forsure what's there, throwing money and parts at it is not what to do. Need to see exactly what you have in your hands. That's the gamble with buying anything used in this case sounds like they put it together with what they could find and maybe didn't know about the small differences that are big problems if not the correct parts.
24x black
58x white
Like Merv said, there could be other underlying conditions causing your issues.
Like I said above it may not be that it could be Cam timing. People have messed that up before. From there make sure all your Rockers are properly tightened to spec.
