Dead end LS1? Build or Sell?
435hp cam only LS1 that ran 10.98 @ 125 right here
modest goal would be 450whp HCI LS1. There’s dozens of ways to do it.
there’s 3-4 LS1 on here the have made 520-540hp. Fairly well documented. If you don’t wanna believe Hios dyno that’s fine, but there’s Darthv8er that maid 540 to the wheels with a LS1 and the same cam and intake as Hio. Tony Mamo had a build last year that made 504 off the hop and later made 520 to the wheels with a fairly mild hyd cam. Chris1313 made 520 to the wheels through a stalled auto like 10 years ago. So, sorry you 427 makes as much as max effort LS1 but bear in mind max effort LS7 can make 650-680whp so your leaving a little on the table dude.
Your never going to see a big gain here unless you spend some money.....but with the advice I just gave you I know you would be blown away and absolutely thrilled with the results
22 years ago I built a 383 that made 535 at the wheels with parts not nearly as good as the stuff Im selling today
Can you do if for the type of budget you were originally discussing.....clearly not.....but you have to be committed in this hobby if you want to really shine and part of the commitment means spending the money to build things correctly
Or you spend half of what it might cost to do it right and only gain a third of the performance increase Im discussing here.
You have the foundation there to get you where you want to go but you have to be willing to spend the money to get there or start saving so maybe next year you achieve what you want
It's simple really.....but half measures never provide big changes and your left feeling disappointed with the money spent and the final results.....it's cheaper to build it properly the first time in the long run
If you have an interest to learn more call or email me and we go from there
My 383 in my C5 circa a video taken in 2005....and keep in mind the new heads that I offer now blow these older heads away offering even more potential (the old timers on this board have already seen this video Im sure)
Regards,
Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Lots of claims and what not in here, I mean if a car/engine is set up for road racing it needs to live a lot longer at high rpm and have a wider powerband than a drag or street car running times in negative DA then claiming SAE power on the dyno, which could be a 40-50 hp difference (uncorrected vs SAE). Most of this path is already proven decades ago and yes the outliers are doing quite well, but it's done in ways that are quite possibly not for the other guy to reproduce in his cars intended usage. Obviously there are some faster combos out there and I don't want to take away from that fact as it takes talent to put it all together.
I had a traditional SB then went to an iron 6.0L with LS3 heads and have a blast every time I take out my ride. Mild cam- 478 ft/lb torque @5000, 507 hp @6100 at the crank with more available and plenty of room to grow with.
Cathedrals work slightly better down low but I've got 350 @ 2000rpm, 400 @ 3000 torque etc..+.........match your rear gearing to the trans gearing along with a good tune and you should be good to go.
5.7s are pretty legit.
I don't think my 5.7 is max effort at all. It’s really pretty basic ****. Just built off of jaiks combo with a lil' more this and that.
2 more points of compression and 20* of cam, light weight rods, knife edge crank would get it close to max effort.
Bolt on ls7s has made 540whp and nearly 500wtq.
With that said I've always been a proponent of good bolt ons. 450whp is oe cam territory. My bolt on ls6 made 451whp 423wtq. Limiter was set at 7200 rpm. I think a good set of ported milled 243s and a ls7 cam could get near 500whp.
His 427 definitely needs some help.
If you gut a fcar and it still weighs 3300lbs.......then you're just ******* stupid at that point.
the cam in my 5.7 is nearly the same as the "stage 4" btr. No need for 4 k clutch dumps to leave a stop light. It cruises in 6th gear fine.
Nothing more than a stock LS7 with bolt ons...Same compression, same size CNC heads with just a bigger hyd. cam, 102 intake and TB with KOOKS 2" headers and 3" true dual exhaust.
If you didn't cross your t's and dot your i's on the build that's on you. 600+ whp is pretty easy for a ls7.
Sometimes it isn't about taking big swings at ****. Maybe just a few small changes here and there......that's usually what makes the difference.
I've said it on here before......you can turn a ls into a sbc if you ain't paying attention. Build on what they gave you.
I had my 4 cylinder Honda running under the national record in D/modified. The national meet I was going to enter at US131 Dragway in Martin, Michigan, got rained out. By the time the next national meet came, it was out of state. Most 20 year olds dont have the $$$$ to run around chasing records. That, and the record had dropped almost a full second. I simply didn't have the resources. So no matter who you are, there's always someone faster/better/more powerful. It's like a Mike Tyson syndrome. You're the baddest man on the planet......Until someone badder comes along and kicks your ***.....Last edited by grinder11; Feb 14, 2026 at 09:47 AM.
nothing.......love them. Would like to revisit a build with one someday and make more asses raw.
I would look to turn a sbc into a ls......while utilizing oe components as much as possible......including heads. A 500whp oe headed sbc is entirely possible.
