Big bore/short stroke, anyone try it?
Old Aug 2, 2004 | 02:58 PM
marc_w's Avatar
This thread realates to mine a while back, where I was wondering why my little japanese inline four motorcycle can pull cleanly from 2,000 rpm, all the way up to 11,000.
Dyno here (mine's actully the grey lines - the red lines are from the re-cammed '04 motor)
The torque curve is pretty flat for a shot stroke / big bore setup.
Old Aug 2, 2004 | 11:37 PM
BurnOut's Avatar
Re: valve springs; you have to consider that virtually all of the high revving (7k+) motors out there are using 4 valve heads... which means that the valves themselves are smaller/lighter, and usually aren't opened over half an inch. Also, as someone else mentioned, OHC setups don't need to run as much spring pressure because they don't have to handle the motion of the (relatively heavy) lifter.
Old Aug 2, 2004 | 11:53 PM
Warbird's Avatar
I haven't reduced displacement but I did go larger bore and smaller stroke on my new motor. 4" bore and 3.875 stroke
