Big bore/short stroke, anyone try it?
I looked at doing the 4.8 liter crank which would destroke the 388 back down to a 350 but to me the extra 38CIs will do more than the RPM capability (9K RPM is a lot to build for
true, but lots of boost helps make up for it...
I think the reason nobody has done it is because they are all going "why spend all that money on a smaller engine"
When you start spending a lot of time above 7200 rpm, you want to make sure everything is light weight and up to the task too.
Weird concept, but it could judt work.
Another benifit I could see would be for the guys that race in the catorigy setup for cars less then 360 cubic inches.
You could acturally have a all bore motor running a 4.8 crank and get get a lot more out of your combo then just a 347 build.
You would get more air from the heads, and might even beable to run a larger cam????
Well if I was made of money then I would consider it just to see this idea in action, but Im not.
Your little big bore motor will make much the same horse power as a bigger motor but it would make less torque.
Another downside to high reving motors is the expensive valve train you need to handle it....definately a solid cam and adjustable rockers, titanium valves, retainers, you would be replacing springs more often and the launches would be at a higher rpm making for either a nasty clutch or a large converter that would be less efficient.
If you build a motor build it as big as your rules or cube/wieght class allows.
Some friends of mine race in the small cube classes...one for intance runs a 302 cube SBC he launches @ 9,000rpm changes gears @ 10,500. Sure the thing sounds awesome but he brings @ least one set of valve springs with him to a meet and never races two meets on the same springs....food for thought.
To have a small motor that would make the same horsepower as a bigger motor it wouldn't be near as friendly to drive.
For the same money a bigger motor will be nicer to drive less, maintenance and kick a small motors *** at the track.
exactly
I think someone should do this.
I bought a 4.8/3.27 stock crank but recently threw it out since nobody would buy it.
It could work great in a CI limited racing class.
Originally Posted by JL ws-6
Something that you could drive around on the street, shifting like a normal street car, but would have the rev's and power to go long with it when you want to take it to the track. Something that would allow you to take ful advantage of the 6 speed, where you could run a 4.56 or 4.88 gear and just use the 5th and 6th gears more. I know that my car on the highway in 6th gear at 90 is only turning about 2K withthe 3.42 rear. I figure that at 65 in 6th gear wit 4.56's it would be around 2200, still not terrible.
"Actually it would be closer to 2700...still not terrible."
JL was correct: 65 mph is 2200; 2700 rpm would be 90 mph.
The high revving motor may make less torque on the street, but you are running a lot more gear (4.56 vs 3.73 or 4.10s for the typical modified street car). If you're willing to use higher shift points then the typical V8 shift points in daily driving, in town driving should be fine. It just may seem wierd at first using the extra revs; almost like driving a 4 cyl sports car. As long as the oil consumption is under control, I could see this working if this is what you wanted to acheive.
Personnally, I like sticking with the stock crank and going bigger bore with the goal of a 7000 rpm street machine with 4.10s.
