Ls/Lt Hybrid
It’s an oddball combination for sure, but I’ve got a great set of complete CNC heads and a block that is all prepped. I figured I might as well use what I have and save a little cost since I have to source everything anyway.
Thanks again!!
Thanks again!!
I have to get all the other components anyway so I thought I’d save the cost of some heads and use what I have.
Is there any reason I can’t just put in an aftermarket set of actual gen V -10cc pistons from the get go? Or maybe a set of gen III/IV at a -10cc with the dish giving the valve clearance? Ballparking it seems the compression ought to be in a decent area with a 6.125 rod and a 4” crank. Little over a 10:1 or so
Do the Gen V dish pistons still have a pronounced direct injection “splash pad” or would it be minimal enough to not have a significant effect on the quench?
If it was still the stock bore instead of 3.800, I’d use a couple singles to experiment on. After a couple oversized, it starts to not get far off just saving up a little more for custom ones if it didn’t work.
Cams aren’t too tough to track down as there’s several places offering them.
I’m soon to start the dowel drill out, which is my only wildcard without buying the expensive jig kit. From what I’ve come across digging around is others have been far less precise than I had in mind and it’s worked just fine.
