What application would this cam be best for?
Old Jul 29, 2004 | 09:56 PM
Z28Venom's Avatar
Default What application would this cam be best for?
214/222 .520/.528 114
Did a quick search and read a small bit about it not being that good for N/A applications..
Reason I'm interested..
-Cheap
-Emission Legal
-Should handle a 150 shot extremely well
This cam w/ S2 heads..
Old Jul 29, 2004 | 10:02 PM
Cheatin' Chad's Avatar
There's really no reason to have that much extra exhaust duration on a mild N/A motor. LS1 heads flow well enough on the exhaust side that a split is not neccessary in most NA applications.
Introducing Nitrous to this cam would probably work very well considering its a 114 and you have the extra exhaust duration to help get it out as fast as it is coming in.
Old Jul 29, 2004 | 10:51 PM
Ferocity02's Avatar
Looks like a N2O cam maybe? Thats a ***** cam if you ask me. Why not a 224/224? It will pass CA emmisions, I am sure it will pass Hawaii emmisions too.
Old Jul 29, 2004 | 11:01 PM
pdd's Avatar
pdd
i agree
Old Jul 29, 2004 | 11:18 PM
THAT is some of the funniest **** I have ever read on this site
I'll say it is mild. In certain instances it could be a very good cam IMO.
Do a search for small cams and you'll see that some people have made very near 400hp cam and bolt on with cams *near* this size.
If that's "*****" I'll have some
Old Jul 29, 2004 | 11:38 PM
slik98z's Avatar
150 shot, **** with the 340 pump id get a set of 30 lb injectors and jet for a 175 shot and really utilize that cam.
214/222 should very easily pass emissions. and it should make pretty good power, granted youd probably get more with the 224, but if you are spraying a 150-175 shot, honestly the extra 10-15 rwhp if that high, from the 224 becomes irrelevent imo.
Old Jul 29, 2004 | 11:50 PM
CaptUSA's Avatar
Old Jul 30, 2004 | 03:19 AM
mooleyz28's Avatar
Yes sir. My friend has a n2o cam in his car and when your doing N/A its a lil difference but when u do it was a power adder... It makes the world of diff. Its a give or take sit. u sacrafice something to gain something else in return... its which u want more that counts
Old Jul 30, 2004 | 03:34 AM
35th SS's Avatar
thats what I was going to say.hey ferocity is this a ***** cam?check sig.Ill have some too.
Old Jul 30, 2004 | 05:03 AM
jrp's Avatar
jrp
SN95 Director
some of the best streetable power bands have been from small cams paired with a nice set of heads.
Old Jul 30, 2004 | 08:34 AM
Ragtop 99's Avatar
what's wrong with your current set-up that you are considering switching out the TR cam?
I'd spend the money on a 224/224 114 or 220/224 115 if you want something milder than what you have.
