TREX cam for stock heads
also im running a stock fuel pump, so if i need a lil more out of the 28's ill put in a 255lph pump
just some advice, your injectors are maxed most likely, you won't be able to control fuel very well, and 13.3 on a dynojet is too lean for the street/strip. IMHO. and you need EFIlive or ease scanner to monitor IPW and DC. I would say this hurting you slightly performance wise, but great for dyno numbers.
they definaly are not hurting performance. jason put 30's in his car over his 26's and didnt make a diff with the 255 pump, just gives more room for expansion when we get to heads. ill change my injectors when i get a 90mm intake. i have efi live and auto tap, theres no problem yet. as far as the 13.3 a/f ratio. that is where i wanted it. all of us are running mid 13's a/f down here with this setup and others. in a few years i have yet to see a problem with any of them yet. that is also where it performs best. i had a friend that ran 13.8 for 2years on his street/strip car with no problems, and mine sees very little street use when its hot due to no a/c in the car thanks Smokin might even get dyno tuned this fri. if I decide to drive the car to work and bring it after.no complains it drives fine on the streets with the 3.89. I mean at the track.wil do some few passes fri. night if it gets tuned that day.same here actually both cars are not daily drivers.sits on the garage on weekdays and sees the track every weekend.taking turns.
