TREX cam for stock heads
Old Aug 2, 2004 | 03:02 PM
ONEQKSS's Avatar
Default TREX cam for stock heads
i was wondering what kind of spring should i used pls let me know thanks
Old Aug 2, 2004 | 04:32 PM
MurrayFormula's Avatar
gold patriot dual springs
Old Aug 2, 2004 | 05:11 PM
DanZ28's Avatar
Or Comp 921's, or Crane 832's..
Old Aug 2, 2004 | 09:04 PM
BuckeyeROC's Avatar
King of Pigskin Knowledge
Put in the Patriot Gold dual's for my T-rex. Just finished the rod bolt install tonight, so everything is still torn apart.
http://community.webshots.com/album/158370128KBrCmy
Old Aug 2, 2004 | 09:12 PM
pir7tr's Avatar
You can use 918s.
Old Aug 2, 2004 | 09:21 PM
JZ'sTA's Avatar
Originally Posted by pir7tr
You can use 918s.
no thanks
Old Aug 2, 2004 | 09:29 PM
ONEQKSS's Avatar
Patriot Gold dual's .... that will hold up 600+ lift ... sounds good thanks guys
Old Aug 2, 2004 | 09:59 PM
BuckeyeROC's Avatar
Should be .650" lift.
 Michael S. Palmer
Old Aug 2, 2004 | 10:07 PM
ONEQKSS's Avatar
thanks
Old Aug 2, 2004 | 10:57 PM
jrp's Avatar
jrp
SN95 Director
You can use 918s.
:umm:
Old Aug 3, 2004 | 01:41 AM
35th SS's Avatar
crane duals here.
Old Aug 3, 2004 | 01:47 AM
BigBronco's Avatar
921's from comp or patriot gold duals or Isky valvetrain will get the job done
Old Aug 3, 2004 | 02:46 AM
2MuchRiceMakesMeSick's Avatar
I bought crane duals, its what thunder reccomends for the trex
Old Aug 3, 2004 | 06:17 PM
SMOKIN01TA's Avatar
i dynoed mine with cranes and compared it to a identically set up car with comps, the cranes with .030 shim carried out better. im spinning it up to 7200 with no problems
Old Aug 3, 2004 | 06:55 PM
DanZ28's Avatar
So thats three Trex people that posted all running Cranes with no problems, FYI!
Old Aug 3, 2004 | 07:59 PM
ONEQKSS's Avatar
thanks guys
Old Aug 4, 2004 | 12:15 AM
josep shortt's Avatar
Default trex cam what is the best head for this cam?
[i have a 2002 ws6 and i have bought a trex cam with comp dual springs and am thinking of buying either afr heads or going to bowling green and having a set of 5.3 heads ported and having the pistons fly cut,how much more power will this give me than just using the stock heads?
Old Aug 4, 2004 | 01:43 AM
ONEQKSS's Avatar
?????????? i wanna know ???????????
Old Aug 4, 2004 | 03:41 AM
35th SS's Avatar
Smokin how many pounds inj. you runnin with that bad boy?have 28s right now.wondering it would be enough.thanks.
Old Aug 4, 2004 | 11:20 AM
DanZ28's Avatar
I'm not SMOKIN, but, I run the SVO 30# inj (36# really) at 63 PSI with my Trex setup and it runs between 82-88% duty cycle at WOT. Thats on a 430 RWHP A4, I'm betting you are close to running 100% at WOT on the 28# inj. You have auto tap or EFI Live?
Dan
