help - locking flywheel for cam swap...
Old Jun 30, 2005 | 03:19 PM
02NavyBlueZ's Avatar
Here is the tool snapon sells, another company makes it for them though..
http://store.autotoolexpress.com/gmhadapupu.html
Old Jun 30, 2005 | 05:42 PM
calongo_SS's Avatar
I bought the Kent Moore tool it's a bit pricey (~60) but works like a charm. I wouldn't use anything else.
Old Jun 30, 2005 | 05:58 PM
code4's Avatar
I sell these for $40.00 + shipping (with permission from this site) It works great, I even had a need for it the other day on my M6 when I was taking off the flywheel. It holds the stock & ASP pullies.
Old Jun 30, 2005 | 06:11 PM
redbandit98's Avatar
by the way..i used the exact same tool in the exact same metod in the above picture..that tool is worth every penny..the puller also worked great after i figured out how to get it aligned properly..i would highly recommend it.
mat
Old Jun 30, 2005 | 06:24 PM
LETZ RUN's Avatar
i put the car in gear on the ground and broke it loose?
Old Jun 30, 2005 | 06:30 PM
calongo_SS's Avatar
That works fine most of the time with M6, but with an auto trans it aint gonna happen.
Old Jul 6, 2005 | 08:26 PM
Mitzelj's Avatar
Does this work Y-body(Vette) pulleys as well?
Jeff
Old Jul 9, 2005 | 10:43 AM
code4's Avatar
The vette has the same pulley so yes it will fit. I remember another vette owner inquiring about the tool and if I remember correctly you can not use it from below as illustrated in the picture in this thread.
