What Block Is Stronger Ls1 Or Ls6
Old Aug 5, 2004 | 02:20 PM
hydfixer's Avatar
Default What Block Is Stronger Ls1 Or Ls6
I am having a blocked sleeved for a 436 CID is there a differance between the to blocks?
Old Aug 5, 2004 | 02:39 PM
Ben R's Avatar
Most machinists familiar with the LSX motors will tell you to try to find a used LS1 block, as they are the best candidates for re-sleeving.
By the way, who is re-sleeving your block?
Old Aug 5, 2004 | 02:49 PM
Boostaholic's Avatar
I have a resleved LS1 block thats already bored to 4.000 if your looking for one to bore out even more, I'm not sure how much bore they can take though. I was always under the impression that you had to go with a different block for bigger than 4.030 bore on the alum resleved blocks.
Old Aug 5, 2004 | 02:50 PM
hydfixer's Avatar
MTI Why do you ask?
Old Aug 5, 2004 | 02:54 PM
hydfixer's Avatar
Thanks But I need to go to 4.130
Old Aug 5, 2004 | 04:23 PM
Quickin's Avatar
So why not buy it and bore it more?
BTW, how are you getting a 436 with that bore size (4.130)?
Old Aug 5, 2004 | 06:02 PM
hydfixer's Avatar
I am not sure, 4.130 bore, 4.125 stroke what is it then?
Old Aug 5, 2004 | 06:05 PM
hydfixer's Avatar
I already have a new LS6 block, Wasn't sure to sleeve the LS6 or use it as a core for a lS1. What sleeves do you have in your block?
Old Aug 5, 2004 | 06:17 PM
Colonel's Avatar
Lightbulb
442ci
Old Aug 5, 2004 | 06:41 PM
hydfixer's Avatar
Originally Posted by Colonel
442ci
Thanks, what would it be with 4.00 stroke?
Old Aug 5, 2004 | 06:44 PM
Colonel's Avatar
http://www.bgsoflex.com/displacement.html
Old Aug 5, 2004 | 09:13 PM
hydfixer's Avatar
Thank you!
