What are replacement bearing numbers for LS1?
Old Mar 25, 2003 | 02:36 PM
SPANKY LS1's Avatar
Default What are replacement bearing numbers for LS1?
What are the part numbers for rod, main, and cam bearings for a LS1 engine? I am assuming Federal Mogul makes all of them, corect? What other kind are there? King? TIA, Shawn
Old Mar 25, 2003 | 07:32 PM
SPANKY LS1's Avatar
Default Re: What are replacement bearing numbers for LS1?
TTT
Old Mar 25, 2003 | 08:20 PM
Country Boy's Avatar
Senior Member
Mains are 152M
Rods are 8-7100CH
I dont know about the cam bearings since a shop did mine... Call Thunder and ask them <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 26, 2003 | 10:03 AM
Fireball's Avatar
rod bearings are just standard SBC rod bearings (only part in common with older Chevy engines)
Old Mar 26, 2003 | 10:17 AM
BIGBOS's Avatar
How much does a full set of bearings usually go for?
Old Mar 26, 2003 | 06:40 PM
Racefan12's Avatar
i think the cam bearing number is 1888M or 1889M...expect to spend about 60-80 bucks for rod & main bearings
