ATTENTION: A Cure for ticking
I figured that was the cheapest place to start so I ordered one and installed it and KAPOW! No more ticking!
I installed my original o-ring properly when I did my cam install. It was not cut or anything when I removed it. You can clearly see why it wasn't sealing. It has a squared off shape to it from being compressed for so long.
I did a crap load of searching and I made a post and it seems that most people don't believe that the o-ring can cause ticking if it's installed properly.
I know that there are a lot of other people who are just living with their ticking LS1's. Hopefully, this info can be made sticky for or something. I'm gonna try to email JMX and recommend that he add the o-ring to the list of install parts on ls1howto.com
From all my searches and personal experience, 35 psi of oil pressure at idle is the minimum for our LS1's. Sure, less my not destroy your engine or anything but it indicates you have a situation that needs attention.
HERE ARE PICS OF THE OLD AND NEW O-RINGS
? The ticking used to come and go , but now it is here to stay , along with the drop in oil pressure . Any help will be MUCH appreciated !
Thanks in Advance ,
Joe
Thanks in Advance ,
Joe
-Mike
The tick was so loud, that it DID sound like it was coming from the bottom of the motor. It could be heard through the firewall, echoing off of surrounding cement walls, etc. etc.
It ended up going away on it's own.... maybe 4 weeks after I initially did the swap?
TIA ,
Joe
