G5x3 with N2O?
Old Aug 8, 2004 | 06:22 AM
chris2000ss's Avatar
Default G5x3 with N2O?
is anyone running N2O with this cam??installing this cam very soon and need to know if there compatable...
Old Aug 8, 2004 | 10:00 AM
Mr. B's Avatar
I'll let you know soon..
Old Aug 8, 2004 | 10:17 AM
mike c.'s Avatar
i have the g5x2 cam w/n20 and it's a beautyful thing.
Old Aug 8, 2004 | 10:18 AM
Kenny D's Avatar
The G5x3 is a nitrous cam.
Old Aug 8, 2004 | 10:52 AM
COOL!!! I was hopeing it would be a good N20 cam..I didnt want to get rid of my NOS kit thanks guys you made my day !!!!!!!
Old Aug 8, 2004 | 11:45 AM
WS6snake-eater's Avatar
If you are going to keep the dry kit, then you better upgrade your injectors and pump with that cam, or you will run out fuel while spraying. Your other option would be to upgrade to a wet system. I have that cam with heads and the whole nine yards, and a wet system. I already have the upgraded pump. I am going to actually be converting it to a dry shot, and upgrade the injectors. I want to be able to spray through the MAF and retard the timing, so that's why I'm switching to the dry shot and bigger injectors.
Old Aug 8, 2004 | 12:20 PM
I have the fuel pump and injectors worked into the plan but,I'm not sure which ones i'm going to go with...do you have any suggestions on a fuel pump and what lb injectors to use??? I want to do heads later also
thanks!!!
Old Aug 8, 2004 | 02:15 PM
Quick 99's Avatar
a friend is putting over 600 on a tnt 150 shot with that cam and a good set of heads
i hope to be there sometime soon
Old Aug 10, 2004 | 01:26 PM
anyone else ???
Old Aug 21, 2004 | 03:05 PM
johnboy's Avatar
TTT for you as I am thinking about spraying mine and am wanting more track numbers before and after the nitrous!!
Old Aug 21, 2004 | 11:17 PM
blue2000Z28's Avatar
good, im thinking abot running n20 also, but i want the cam first. How come people use TNT?? i use edlborc(sp) is there a difference?
Old Aug 22, 2004 | 02:03 AM
johnboy's Avatar
Im guessing your referring to edelbrock? Im going to go with NX... been around it and trust it
