How to use Larry spring compressor tool
Old Aug 8, 2004 | 08:45 AM
GETSOMZ28's Avatar
Default How to use Larry spring compressor tool
All, I am halfway into the cam swap. I am ready to do the springs and I have the Larry's spring tool, but I am not quite sure I understand how to use it. I see the threaded bolt goes into the rocker arm hole, however it seems like the tool is so long the back rests on the head. Wont it dent the head since it is made of aluminum??
Any help is welcome.
Thanks,
Scott
Old Aug 8, 2004 | 09:11 AM
C_B64's Avatar
that is where it is supposed to rest. screw your stud in, place the tool on the stud, then put washer and nut on. then take a ratchet and tighten until you can get the locks off. then loosen
Old Aug 8, 2004 | 09:21 AM
GETSOMZ28's Avatar
Thanks for the clarification. I was just concerned that it would "dent" the heads with the pressure it takes to compress aftermarket springs (Comp 918's).
Old Aug 8, 2004 | 09:31 AM
kenkaru's Avatar
you could always just use a piece of cardboard or some sheets of paper as a pad.
Old Aug 8, 2004 | 03:07 PM
DanZ28's Avatar
You will be surprised how little pressure is put on the heads. 90% of it is over the stud and top of the spring, it won't mess the head up
Dan
Old Aug 8, 2004 | 06:37 PM
GETSOMZ28's Avatar
thanks guys, that is the greatest tool ever!! super easy to do the springs.
Old Aug 9, 2004 | 01:38 PM
XIII's Avatar
Where did you order the tool from? I need a spring compressor that works. It took forever with the one I borrowed from Autozone. Thanks.
Old Aug 9, 2004 | 01:42 PM
Predator's Avatar
Trey, email Larry at:
larry98@alltel.net
Old Aug 9, 2004 | 05:36 PM
Larry's Avatar
Sorry Trey but unless I can get at least 10 more guys wanting the tool I won't be making any more. Orders were too slow to stock the tools.
Glad the tool worked out well for you Scott.
If you are concerned about scraching the head then a piece of aluminum tape on the tool should be good insurance. I didn't use anything when I did my head and no scraching. I did keep the tool and head clean.
Thanks to all who ordered. I appreciate your business.
