Spring Life With TREX
Old Aug 9, 2004 | 09:38 PM
2002$$'s Avatar
Default Spring Life With TREX
how many miles have you guys gotten off your springs, while running a TREX cam? all you radical daily drivers.
Old Aug 10, 2004 | 02:02 AM
35th SS's Avatar
installed mine 3weeks ago.less than 100mi.not a daily driver.
Old Aug 10, 2004 | 02:19 AM
2MuchRiceMakesMeSick's Avatar
I am installing one this weekend. I will probably change mine every 15k.
Old Aug 10, 2004 | 09:58 AM
Boostaholic's Avatar
Wow, is spring life really that short with this cam?
Old Aug 10, 2004 | 10:03 AM
gator's 99TA's Avatar
i personally would inspect every 12-15K miles and probably change them. the ramp rates and lift are not normal street oem issues lol. you have a race cam bro!
35th SS's Avatar
20-30k .might want to verify with thunder racing.
Old Aug 10, 2004 | 05:38 PM
2002$$'s Avatar
but every 12-15k and you should probably never have any probs right? also any ptv clearance issues w/ stock heads? do you think it would be similar with a G5X3?
Old Aug 10, 2004 | 06:53 PM
2002$$'s Avatar
any1?
Old Aug 10, 2004 | 09:29 PM
BuckeyeROC's Avatar
King of Pigskin Knowledge
It's a fairly new cam and really not a daily driver type cam for most people. I don't think too many people have a lot of miles on them yet. My T-rex and just about every other bolt-on install is just about finished. I got the Patriot Gold springs and if they last 15k miles, that'd be cool with me. It'll probably take me 2 yrs to put 15k on the car. Probably similar to the G5X3.
Should be no PTV issues with this cam as long as the heads aren't milled, the pushrods are stock length, etc.
Old Aug 10, 2004 | 09:42 PM
2002$$'s Avatar
thanks buckeye.yeah i called tr,they said about the same.15k would be fine with me too.
Old Aug 10, 2004 | 09:44 PM
SeeYaSucker's Avatar
I have about 3k mi on my cam, but I will pressure check them every 15k mi for saftey I'm using Patriot Gold duals
Old Aug 11, 2004 | 12:40 AM
Any daily drivers in here? I am putting this on my daily driver.
Old Aug 11, 2004 | 01:17 AM
35th SS's Avatar
think thiers 1 or 2 as daily driver. not sure about smokin01t/a has in his car.he might chime in here.pretty brave to run this cam on your daily driver.guess different strokes for different folkes.hope you like to drive it everyday loping hard.good luck.
Old Aug 11, 2004 | 06:02 PM
2002$$'s Avatar
who doesnt like loping hard.i dont mind driveability,just worried about getting stranded.i think if i check every 15k i should be fine.
Old Aug 12, 2004 | 07:03 AM
equandt's Avatar
Good luck. I bet you change that cam in less than 5000 miles. You're going to have your hands full with a T-Rex in a daily driver.
Old Aug 12, 2004 | 09:59 AM
35th SS's Avatar
I concur.unless you dont mind doing another camswap install.go for it.
Old Aug 12, 2004 | 08:04 PM
2002$$'s Avatar
thats it?!?5,000 miles?!?**** it ill get a TSP 231/237.thats a little bit too often for me. still an awesome cam,along with the g5x3...spring life must be about the same as the trex, right?
Old Aug 12, 2004 | 09:13 PM
MurrayFormula's Avatar
i think that you may have misunderstood what he was saying. not the spring life for 5000 miles, but the fact that a cam like this you may not like on a daily driver. so he is saying that you would probably change after 5000 miles.
Old Aug 13, 2004 | 08:13 AM
I drive it 4 days out of the week to work. The rest of the time it sits in a garage and go everywhere else in my freinds, roomates, girlfriend(s) cars. But with a good tune it wont be that bad. I have a freind with a cam almost as big as the trex in his SS and it drives fine. He also has a full spool and I dont mind it that much even though people say they are horrable on the street. I guess some people can tolerate more then others
Old Aug 13, 2004 | 05:23 PM
2002$$'s Avatar
oh i thought you guys meant spring life.....i dont mind the driveability...i think i can handle it.i like a loud, lopey car.im gonna try it, if i dont like it ill change it.
