Futral F13 cam specs?
#43
Originally Posted by gomer
If I was ordering a cam tomorrow for my car I'd order a FM13 114+4.. that'd be the ****. Nice smooth idle, *** kicking midrange and ungodly topend... damn, time to change cams again
Nice A4 grind though, Hmmmmm
#45
So let em get this strate XE-R lobes suck but the F13 lobes even though we don't know what they are are awesome and they won't kill springs. No it also seems u guys like this cam on a 114? My cam is currently on a 112 and it works pretty good (425/400 on a Z06-stock heads)but I just wanted a bit more and I heard great things about the F13. Reason I wanted just a bit more is I just finished installing a set of AS 5.3 stage 2.5 heads. I drive the car every day so i don't want to get stuck with something that bucks under 2 grand plus I don't want to buzz the motor to 7 grand either-currently I peak out at 6500 and won't the 114 push the powerband out further. So the F13 on a 112 or a 114-I'll sacrifice a bit of driveabilty for power. And I still have yet to find out the advertised duration of this cam?
#47
#51
Originally Posted by JS
Still no help?
Will it work with my setup and do u think a 114 is better for my car?
I like the idea of a 112+2...
#52
I run 113+2 now so I think your right,I like lope but it sounds pretty good on a 114 as I heard it via a mpeg.I would imagine my Cartek S2X heads would LOVE this cam and I could shift the car around 6700
My cam now is a Xer lope and the do make the springs tick alittle too much for my liking.I love the idea of a cam thats alittle easier on valve train parts.I run duel springs and good pr so I'm okay Gomer.Do u really think I'll pick up RW from 4K on over my 224-580 113+2 XER?
I'll call Allan this week
Thanks...
Thanks...
#54
So I'm getting the feeling u guys don't like the comp XE-R lobes-is it because they are too hard on the valvetrain? I thought the Xe-R lobes are badass?
#55
Originally Posted by JNorris
It really does not matter if there is P to V contact.
What I'm talking about is the balance of the P to V numbers. You're still more likely to hit an exhaust so if you have very little on both you may still need to trade the intake for the exhaust. Or just realize you are compromising everything to get the cam in there and live with the results. With these no relief LS1 pistons that what a lot of these guys are doing I guess and I know where you're coming from!
#58
Moderator
Originally Posted by racer7088
JNorris,
I understand. Thanks for the more detailed explanation.
John
#59
I was asking 93Polo.
FWIW ICL 107.8 LSA 111.8
Intake duration is 227.7/.57586" of lift and exhaust is 230.9/.59594"
Lobe area int/exh is 27.36/28.19
Vortech the F13 would be worth some ponies over your 228/230 XE grind but i would spend the $$ on a good set of heads.
#60
I do have some awesome heads-I have Jay's stasge 2.5 5.3 heads. I made 450 without a propertune because the dyno broke down. I was looking at the F13 because it has more lift to take advantage of the xtra flow the AS head offers(.6=314cfm) and slightly more duration without killing the drivabilty. I was going to go with the G5X3 but i don't see the need for all that exhaust duration. Plus i still haven't seen the advertised duration of the F13, I know my cam is 281/283. I think my cam is pretty good I just wish it mad a tad more lift.
