Who has bored a 98' LS1 block?
Not sure of the mileage on my block.
But it was supposed to be a Vette warranty take out for oil consumption.
Edit:
Oh yes ... I used Speedpro pistons. Supposed to be a little heavier than the Diamonds. It appears the extra weight is around the wrist pin.
A little more "beef" is OK by me as my setup sees 6K rpm for extended periods of time ...
Edit:
Sounds like the consensus is go for it up to 3.907", lots of success stories so far.
99Silvo, hone according to the piston kit you buy. I went with JE specified for 3.905" ( the pistons were measured to 3.901" with 0.004" for tolerance ). I have seen a Lunati kit for the "stock" bore size of 3.898" even. Just use whatever sizing is recommended.
Oh yeah, make your piston choice first then go to the machine shop. I made the mistake of going with 3.898" and had to repay another $200 to get the rest of my 3.905".
