Has anyone resleaved a iron block?
LS1TECH Sponsor
I suspect the iron block will be a bit stronger and will definitely stay straighter than the aluminum blocks under load. The main bulkheads are thinner on the iron blocks so don't expect a great increase in bottom end strength from the material change. You also have to factor in the weight increase of the iron block and the extra cost to machine it.
Steve Demirjian
Race Engine Development
Steve Demirjian
Originally Posted by 1fastWS6
Is that much stronger than the alum. block with the Darton MID sleeves?
