C5R block and C5R heads, fully built 427....daily driver....
For 550 to 600 rwhp there are cheaper ways to get there. Unless you just want to say "I have C5R parts" why? I admit if I had the money I would go all C5R and custom parts but since I don't I can't see why. If you got the money go for it but please, post pics of the build!
Originally Posted by steve-d
C5R bare heads cost @ GM Parts Direct. This is a cost for each:
GM PART # 12480090
CATEGORY: Engine Cylinder Head
GM LIST: $1,676.18
OUR PRICE: $1,173.33
GM PART # 12480090
GM LIST: $1,676.18
https://ls1tech.com/forums/generation-iii-internal-engine/203010-f-427-predator-550-rwhp-daily-driver.html
That would make more sense to me.
Cyphur-traq I'm in business with you. I call the range, and you squeeze the trigger.
Originally Posted by LMEengines
Hello Quickin,
I've researched this setup for one of my customers in the past. We could build you a setup that would work great. Basically it would consist of C5R heads setup for a Hyd. roller cam, dished pistons to lower the compression to 11.5. This would be a killer setup for the street. RWHP would depend on how big of a cam you could live with. But I would estimate the RWHP thru a 6-speed to be in the 550 to 600 range.
As far the price of the heads I can do a set of C5R heads for you for around 6,500. If you are interested give us a call.
6600 rpm clutch dump of death Administrator
You can either do a Kinsler setup, or one of the 8tb setups from Australia. You can keep the stock computer and convert it to a Speed Density setup. There are several Aussie's playing with C5R head setups.
Kurt Urban (427) from Wheel to Wheel has done numerous C5R head projects he has basically stated a C5R head is useless unless its on a big bore motor. But if you go 427, I think you can make big power. The benefit of an 225 AFR is it will work with a stock manifold. The C5R requires something custom, but if you tune runner length, etc... I think you could make crazy power.
You might contact Kurt for more info.
My ARE 436ci Trans Am, I want to leave it alone, it runs to friggin sweet to change it or better it. Its a perfect daily driver with gobbs of power.
So how much could be had from using C5R stuff with a 427ci? If its not much more than 725 FWHP why bother spending the cash?
Originally Posted by term
Quickin, your projects are sick, what is this beast going into if your T/A is keeping the stroker?
I want to have a motor built thats completely insane for another WS6. I'd like to have over 600 RWHP on-motor, then spray it with a 250 shot or maybe more. The MORE Performance motor seems like the baddest one out there.
I'd like to put this in a WS6. The 1,600 hp package. I got a quote for $55,000. TH-400 tranny, built Ford 9" rear-end, full suspension and a brake upgrade, fully tuned and ready to pick up.
http://www.bankspower.com/twin-turbo-products.cfm
C5R In Australia
C5R Block and heads. 440ci
740fwhp 640foot pound torque.
#33
#34
Originally Posted by granitemonkey
the $49,000 Twin-Turbo setup from Lingenfelter is starting to look like a bargain
There is no comparison.
#36
Originally Posted by angst911
ummm.. did you hit your head again?
Then a 300 DP shot on top of that I'll know in about 1 month if this will happen, if so it will be going into another WS6 street car.
Roll race KING.
#37
Roll race KING.
#40
Originally Posted by NastySSoo
Keep us updated. It sounds awesome!!
