A few valv spring questions
Old Aug 18, 2004 | 07:03 AM
Baluchitherium4's Avatar
Default A few valv spring questions
I think I'm going to go ahead and replace my valve springs on my car due to what I saw on my last dyno.
I do plan on doing a cam in the future but I don't know when. I don't want to take a chance on dropping a valve.
Now for the questions:
Will LS6 valve springs a good choice for a stock cam motor? Will they directly swap with the stock springs? What year Z06?
Where do I buy the valve spring compressor for the LS1?
Is there anything else I should do while I'm doing the valve springs? Valve cover gaskets?
Is there a way to keep the valves from dropping without using compressed air?
Is it a good idea to check the push rods while I have the valve covers off?
Anything I should know before I do this?
Thanks in advance.
Old Aug 18, 2004 | 07:06 AM
PREDATOR-Z's Avatar
Use stock replacements or Comp replacements.
LS6 valves are longer which leads me to believe there is a variation in the LS6 springs too.
Old Aug 18, 2004 | 07:35 AM
code4's Avatar
http://www.ls1howto.com/index.php?article=23
Old Aug 18, 2004 | 09:47 AM
MyLS1Hauls's Avatar
LS6 springs will work. The 02+ LS6 valves arent much longer. When installed in LS1 heads, the installed height will be a little less, but coil bind wont be an issue. You can just use an normal OHV spring compressor. You can use the TDC method of changing springs, but I still like the compressor method the best.
Old Aug 18, 2004 | 10:03 AM
Zach@Texas-Speed's Avatar
i use top dead center method and never had a problem, check as many parts as you have access too while doing mods
