Comp 918 broke with few miles
Originally Posted by Naked AV
Why do I have to check aftermarket springs once a year or every 15K miles, when I can go 100K miles on stock springs? Why can't they make aftermarket springs to last 50-75K miles, or more? What's so hard about that? GM can do it, why can't Comp?
Also, stock GM springs barely have enough pressure to restrict valvefloat on the stock LS1/LS6 cams.
I'm the guy it happened to. Like Tech said, no abuse...(see seperate thread at around 2:30 am this morning)
"The bent valve punched #3 piston pretty good. The single ding looks almost like you had the piston flycut. But not so deep.
WHAT ARE MY CHANCES? Can these LS1 pistons take a hit like that and keep on ticking? Or Is it likely or not likely there is more damage to the cam, bearings, etc? "
Got one opinion so far, that the motor has to come apart....
Also that newer springs have blue stripes. Don't recall seeing blue stripes, I'll ask mechanic when he gets home, and to measure the ding.
Thanks, Ram
Thanks, Ram
