head studs don't fit on new iron block?
Old 08-19-2004, 05:58 AM
1dirtyZ's Avatar
Default head studs don't fit on new iron block?
did the casting change recently on the 6.0 iron blocks? cause i have a situation where the arp studs that fit on an older motor seem to be too long for the new one. the threads in the block don't seem to go as deep as the old ones.
anyone aware of that? where can i get head studs for it ?( does arp even know of this situation?)
Old 08-19-2004, 09:36 AM
LS1 Tech Veteran
Steve Bryant's Avatar
What if you call ARP tech support. I've talked to them before and they seem to be pretty helpful folks.
Steve
Old 08-19-2004, 11:20 AM
KJ
KJ's Avatar
GM changed the 6.0 block not long ago, and we found out the hard way too! The cam bearings are larger, and they also changed the head bolts. The old blocks used three different lengths, and now the new ones just use two. Last I checked ARP only had head studs available, and were working on head bolts.
We keep the 2nd design cam bearings in stock from Dura Bond. Let me know if I can help with anything!!
Old 08-19-2004, 12:25 PM
1dirtyZ's Avatar
i just talked to arp about that and they said that they are on back order for at least 2 weeks.
the part number for the individual studs (basically the intermediate size stud- bolt) is : ATP5.150-1LGB
any ideas where i could find them?
Old 08-19-2004, 12:51 PM
BTL FED's Avatar
Is there a different casting number on these blocks, because I already have a set of high dollar L19 Headstuds for the old style, and dont want to have to buy another
Old 08-19-2004, 02:34 PM
Dumb Ass Vette Moderator
ls1290's Avatar
I would like to know also since I have a set of $240 ARP LS1 head studs that I am planning on using.
Old 08-20-2004, 12:21 PM
1dirtyZ's Avatar
update: ARP is planning on making the kit, it's somewhere in the "heading" department but the lady said it could be anywhere from 4 to 8 weeks!
from comparing both blocks i saw the new one has a "12" cast on the pass side front of the deck surface.
i guess the easiest way to know is look into the bolt holes ( any one of the middle ones) and if you see the bottom (about 3 to 4 inches deep) then you have the new one.
Old 08-20-2004, 12:27 PM
ls1290's Avatar
Can the 'normal' LS1 stud kits be used with either block?
Old 08-26-2004, 03:50 PM
KJ
KJ's Avatar
The casting #'s are the same. You should have 16 long studs. If you have the new block you will need a total of 20. they no longer use the 4 short studs.
No, you won't have enough long studs.
Old 08-26-2004, 09:16 PM
427's Avatar
On the aluminum blocks they went to all short bolts in all 20 holes. The old block kits will not work on newer block.
Kurt
Old 08-27-2004, 03:57 AM
1dirtyZ's Avatar
so the aluminum block got revised too.....
does anyone think the shorter bolts / studs will resist stretching and thus lifting the head due to the shorter length?
Old 08-27-2004, 08:34 AM
Paul F's Avatar
The new ARP part number is 234-4317 ARP 12 pt Head Stud Kit, 2004 & up LS1/LS6. We have plenty of these in stock and ready to ship. They are $239.99 plus shipping.
Old 08-27-2004, 10:47 AM
1dirtyZ's Avatar
paul, do you happen to have them in 6 pt studs?
Quick Reply: head studs don't fit on new iron block?
