Head Gasket???
Old Aug 21, 2004 | 10:30 AM
02 TA's Avatar
Default Head Gasket???
I am about to put some stage 2, 5.7 heads on my car, but the heads are 98 style and my block is a 02. My question is do I buy the 98 style or 02 style head gaskets or is there a difference?
Thanks Guys,
Adam
Old Aug 21, 2004 | 10:51 AM
PREDATOR-Z's Avatar
Perimiter bolts! How about your valve covers??
Old Aug 21, 2004 | 11:07 AM
02 TA's Avatar
Yes I know that the valve covers are different, but I am talking about the gasket between the head and the block. I am not talking about the valve cover gasket.
Old Aug 23, 2004 | 04:59 PM
02 TA's Avatar
Anybody?
Old Aug 24, 2004 | 10:06 AM
BOTTLE ROCKET's Avatar
2 TA
I know that there is a difference in thickness between the 97-98 gaskets and the later ones that compensate for the larger chambers on the early heads (69 compared to 66)
I also understand that there is an "indention" on the block that requires the use of the early gasket to prevent a water leak. I would think that the use of the later block would eliminate the need to use the earlier gasket for anything other than raising the compression.
You could proably contact one of the head vendors to find out for sure
Old Aug 24, 2004 | 05:06 PM
SNW Vette's Avatar
Post Gasket for Early Heads on Late Block
Hi,
Late gaskets will leak water at cylinder 3 & 6 on early heads.
Late heads can use early gaskets.
I haven’t found a difference in the blocks that would require a specific gasket.
To use perimeter bolt heads on a ’02 block, I would use the NAPA gaskets (graphite type). These are ~0.010” thinner than the late MLS gaskets (that are ~0.062”) and very cheap.
Good luck,
Steve
Old Aug 24, 2004 | 05:13 PM
GPowrie's Avatar
There is a indent on both cylinder heads on 97-98 heads. You will need to use graphite type gaskets on those heads. Cometic makes a MLS gasket that will seal with those heads, but the GM MLS will not seal.
Old Aug 24, 2004 | 05:18 PM
Need2gofaster's Avatar
Not to hijack this tread, but i have the exact opposite problem...I have a 98 and bought some 2000 heads...so i can use the napa 99 and up gasket and be safe right?
