346 to 408 question?
Old Aug 21, 2004 | 10:54 AM
dads toy's Avatar
Default 346 to 408 question?
I am thinking about going to a 408 small block, I have seen these in magazines with forged internals for around 3600-3800. I was told it weighs about 80 pounds more than the 346 but I would get 62 extra cubic inches. Since I was planning on doing a forged 383 stroker, the 408 sounds like a pretty good deal. I was told that the 408 will bolt right up to my current tranny, Will it work with my current heads (yes they will be freshened up)? what about my LS6 intake? Will I have to replace my headers? Just trying to figure what all will have to be replaced.
Thanks for any input
Old Aug 21, 2004 | 10:56 AM
PREDATOR-Z's Avatar
The heads will give you a little more CR, but might be lacking in flow. Stage II LQ9's would be better.
Old Aug 21, 2004 | 10:59 AM
MUSTANGEATER's Avatar
John...
Everything will bolt up just fine except the alternator which is an easy fix from what I have been told. Your heads and intake will bolt up just fine, however if it was my car I'd be searching for a new heads/intake/camshaft combo if you have the money to spend to allow it.
Floyd
Old Aug 21, 2004 | 11:01 AM
JDPZ28's Avatar
You also might want to upgrade your cam depending on what your running now, since you can get away with a bigger cam with the additional cubes.
Old Aug 21, 2004 | 11:27 AM
PREDATOR-Z's Avatar
Why weird? 241 LS1 will give him more CR on a 408 but will be lacking in flow potential.
Stage II LQ9's will provide the added flow and are the correct heads. If on budget try PP stage 2's.
Old Aug 21, 2004 | 11:31 AM
max's dad's Avatar
werd:werd up, I agree, you're correct, true dat
Old Aug 21, 2004 | 11:34 AM
He's not running 241's he's running a 4.8/5.3 casting if I'm thinking right. His heads are already ported and was just wanting to refresh them. Although as suggested He'd be better off with an AFR or LS6 head.
Also you may want to re-read the smiley its
W-E-R-D not W-E-I-R-D
Old Aug 21, 2004 | 11:56 AM
PREDATOR-Z's Avatar
I see said the blind man
Sorry I went 241 because of year of car, Stage II GTP doesn't specify what heads.
Old Aug 21, 2004 | 12:03 PM
TVWilkes's Avatar
I have a special going on the 408 short blocks.
6.0L Iron block
4.0 Eagle crank
6.125 MANLEY H beam rods
Forged pistons
H series bearings
ARP Main studs
Balanced and Blueprinted
$3599.00 outright no core charges .This does not include freight.Call for other options added,oil pumps,timing chains, heads ect....You may compare this to other 408 prices being offered at bargain prices.Notice this has H-BEAM rods and ARP main studs.
