JPR Tool from Thunder.......Against dowel rod
Old Oct 31, 2004 | 08:53 PM
vt2vx's Avatar
Originally Posted by glennster
This works........get 2 X 24" long sections of 5/16 brake lines,bend 5" into an "L" and "oval" the 19" long sections in a vise.Spin the lifters up and insert the 2 19" long sections and turn them to tighten against the lifters,works like a charm.
this sounds like it would work well. being oval it will slide in easy. then rotate them to lift and lock the lifters up. (turning would pull on them a bit at first).
Old Oct 31, 2004 | 10:51 PM
v8maro's Avatar
See this post: https://ls1tech.com/forums/generation-iii-internal-engine/230600-middle-cam-install-need-help-asap-w-rod-lifter-trick.html
still doesn't have answers if you ask me.
Old Nov 1, 2004 | 12:09 AM
luv2spd's Avatar
I used 5/16" for mine with a flat spot grinded the whole length of both of em. I also ground the tip into a bullet shape. They slid in really easy. I didn't even bother to bend it to make a handle b/c it didn't take much force.
