Inch Longer crank bolt
Old Aug 23, 2004 | 03:38 PM
speedo's Avatar
Default Inch Longer crank bolt
Doing a cam and head install and in reading JRPs install instructions it calls for a longer cam bolt to pull the crank pulley, where do I find one, FAST!!
Thanks for the info..........
Old Aug 23, 2004 | 03:40 PM
killer01ws6's Avatar
I got the threaded Rod and nut from a member on here.
I have used it 4 times, works like a dream.
Old Aug 23, 2004 | 03:45 PM
Gimp98TNT's Avatar
I think a waterpump bolt may be a LITTLE small to pull the crank pulley on. I couldn't find one locally, so i had to order one from mcmaster and carr.
heres the link www.mcmaster.com
11 Bravo's Avatar
Sorry, I deleted it. Thought you were talking about the cam lol
Old Aug 23, 2004 | 05:06 PM
Predator's Avatar
I found one at Napa, 120mm. It's not threaded the entire length, but I think it will work fine. I might have to grind down the unthreaded section so it's a smaller diameter than the threads. I don't know if all Napa stores are the same, but the one I go to seems to have very nut, bolt, stud, etc. that you can imagine.
Good luck!
Old Aug 23, 2004 | 05:48 PM
Johnny5's Avatar
I got one at a hardware / specialty store that was the 120MM length. It was not threaded all the way either but worked perfectly to get the pulley off. I believe it was a hardened bolt also but doubt it would matter a whole lot
