will 2000 heads work on a 1998?
Old Aug 23, 2004 | 06:20 PM
Need2gofaster's Avatar
Default will 2000 heads work on a 1998?
I want to buy someones heads that are a 2000....will they work on my 1998 LS1??
Old Aug 23, 2004 | 06:23 PM
slow's Avatar
yes, but you will need valvecovers, and coil pack brackets, and mod the pcv system
Ryan
Old Aug 23, 2004 | 06:27 PM
Ryan
what is the best place to find all of the above? and what mods to the pcv system
Old Aug 23, 2004 | 07:09 PM
i thought b/c of the different bolt patterns(98 - perimeter vs 99+ center) you couldn't use differen't heads...or are the blocks drilled for both??
Old Aug 23, 2004 | 07:24 PM
bigdsz's Avatar
The head bolt patterns are the same, it's the valve cover bolt patterns that are different.
Old Aug 24, 2004 | 10:41 AM
02 TA's Avatar
What head gaskets would you use though? Ones for a 98 or the 2000?
Old Aug 24, 2004 | 10:45 AM
OWENMUSTANG's Avatar
99 up
Old Aug 24, 2004 | 10:46 AM
PREDATOR-Z's Avatar
I think 98. Call a sponsor and find out for sure.
Old Aug 24, 2004 | 04:04 PM
So shouldnt the gaskets be the same if the bolt pattern is the same?
