Another TR224 question
Old Aug 24, 2004 | 02:00 PM
WS6 RULES's Avatar
Question Another TR224 question
Will the 112 LSA on the TR 224 cause any misfire codes? And what about the 114 LSA, same question. Yes I have done searches. I am about to buy this cam and was just trying to get all info I could first. Thanks.
Old Aug 24, 2004 | 02:07 PM
Onyx Z's Avatar
Just about all lopey cams will throw a misfire code. For some odd reason, my 230/226 112LSA didn't. I think the misfire sensitivity was relaxed a little at idle. I'm sure one of the sponsors will do this for fairly cheap.
Old Aug 24, 2004 | 04:44 PM
Ryan02SS's Avatar
Mine never did before and after tuning.
Old Aug 24, 2004 | 04:45 PM
99ssleeper's Avatar
My TR224-114 throws a misfire code every once in a while...not every time I drive the car though. This usually happens if I let it idle for a long time.
Old Aug 24, 2004 | 05:59 PM
glennhl's Avatar
My TSP 224R with 112 LSA threw a misfire code right off the bat. Ran it a month until the tune and never threw another misfire code.
Old Aug 24, 2004 | 07:40 PM
Ferocity02's Avatar
Never had a misfire code in the 10 months of having the cam.
Old Aug 24, 2004 | 08:37 PM
Onyx Z's Avatar
Lemme refrase that, it might throw a misfire code.
Old Aug 24, 2004 | 08:44 PM
2000 Tran Zam's Avatar
my tuner turned off the random misfire code from ls1 edit when i installed my tr 224 112 lsa cam. i guess its hard to tell the difference when a car misfires if it has a cam since its all basically a small misfire.
Old Aug 24, 2004 | 09:50 PM
98TAauto's Avatar
mine threw 100 of them since any cam should trigger them usually. I had to turn mine off in edit. But if you watch on atap, your will see about 20 misfires per cylinder normally per minute..
nothing wrong with it, but a 112 will lope harder than a 114 so givin all things are the same it will set off a tad more misfires
