Domed pistons with 5.3 heads?
Old Aug 24, 2004 | 03:02 PM
Pacific Muscle Cars's Avatar
Default Domed pistons with 5.3 heads?
Does anyone have experience running domed pistons with 5.3 heads? I have a pair of 5.3 stage 3 heads that have been milled .030" and some 12cc domed pistons. I am considering having my machine shop mill the domes to approximately 6cc to bring the compression back down to 12.5:1. Are there any clearance issues that I should be aware of with this combo?
Old Aug 24, 2004 | 03:15 PM
jermstyle's Avatar
What size valves?
Old Aug 24, 2004 | 03:55 PM
The valve reliefs are adequate. I'm concerned about piston dome to combustion chamber interference with .030" milled 5.3 heads. I believe the piston domes were designed for stock 5.7 chambers. Is there enough of a difference to create problems?
Old Aug 24, 2004 | 04:52 PM
jrp's Avatar
jrp
SN95 Director
and i thought my 12.0CR was high . i know for Jasons new setup he's running 5.3's milled and 9.10 effective domes and a big *** cam to boot. my setup is 5.7 heads milled .020 and 6.6 effective domes.
Old Aug 25, 2004 | 07:03 PM
Still looking for anyone who has experience with this combo. I'm curious to know if the domes will require massaging to fit with milled 5.3 heads.
