G5X-2 Results for an A4
<img src="http://home.earthlink.net/~stoney69/Photo.JPG" alt=" - " />
<small>[ March 29, 2003, 03:37 PM: Message edited by: SAINT WS6 ]</small>
HAHAAH, congrats on the numbers man! No doubt she has more in her through open exhaust! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
A4 power <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
SSBoy, Got Me SOM - Yup, 1300 rpm. that or around 1250. 900 rpms might be a little low for an automatic but for a manual that would idle just fine. I'm going to play with it some more when I get back from Spring term.
Y2K2LS1 - Brake wise I do have to hold it a little more than usual at a stop light, but not a big difference.
JF WS6 - The #'s were with the converter locked.
Also, car starts right up off a cold start. It did die once when I put it in reverse, but it fired right back up. The 1250 idle is really not that bad, it does get a little loud sometimes, but that's how I like it <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" /> . I'm sure doing an 1100 or so would still be ok.
Little more info - The valvetrain is Manley 2.02 and 1.60 valves, Tit. retainers, Tit. shims, bronze guides, Manley double springs, CM pushrods. Also want to give praise to LG Motorsports for doing an awesome job!!! I had some problems early with the computer and transmission and they took care of everything free of charge. I've been dealing with them for the past 5 years and have nothing but praise for everything they do. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> to LG!!
<strong> Looks like you have a little valvetrain issues at 6400... </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was just about to say that. Whats up with the dip?
1300 rpm idle? That's insane <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Your stop N go gas mileage is going to go to absolute crap unless you lower that some. Try to get away with 950-1000 or so. 1300 is high..
Also, why did they "upgrade" the coil packs. There isn't any difference as far as I know. Just curious....
Josh
Damian - Yeah, like I said I'm going to lower it when I get home from school. I'm sure it would run just fine at around 1000-1100 or so. 950 might be pushing it though.
Its not as high as you might think <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Try 1000 - 1100 max. In Edit, adjust your IAC settings up just a bit and add a couple degrees of timing and it should work. Expect some cam surge if you lock-up at low rpms (e.g 1300) but I'll bet you can get the idle down to 1050 and have it run well within daily driver limits.
Hard core guys can run 975 rpm. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Just realize Louis said it was set for 1100. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> Does ATAP confirm that?
<small>[ March 29, 2003, 09:27 PM: Message edited by: Ragtop 99 ]</small>
