Who's running 918's w/ .600"?
NO NONE NOT ONE ..... really....
my buddys 02 ta had 2 pistons kissed because of blue stripe failure (with a tiny b1 cam)....
my 02 with .581 lift is showing signs as well...
if you could run these things up to .650 with no problems then comp woule not recomend them to .600
they would say .650 and the only thing that would change would be the PRICE...duh
why would ANY manufacturer sell something for less then they could get for it???
that just dont make sence...
Originally Posted by GTS346
And where's all these threads on Manley springs failing?
Sure the 918's are great and used in a stack of cars, but by the sounds of your posts it makes you out to be a spokesman for COMP. You don't work in the advertising department do you?
Joking buddy, gotta have a laugh here and there.
I'm running 918s with a .598 lift (not an XER) grind and no problems. With their recommended lift being .600 I fall within the appropriate range and why put more hp robbing strain on my motor with oversized springs????
I know for a fact that engineers suggest a safe operating range and that does not represent what a spring will really support before failure. I'm comfortable with what I'm running.
Shorty Director
The 918's are good springs, but my FMS-9 cam killed them in 10000 miles. 232/236 .585/.595 lsa 114 plus 4. I would say get something a lil stronger if you plan to drive many miles. Allan Futral told me to change the springs as soon as I got the chance and my procrastinating cost me an engine.
Originally Posted by jaberwaki
2 1/thousanths from max lift?
coil bind robs more hp then good springs
Check sig. Many people do the same thing. There great springs just change them as needed. I'm not the least bit worried about my setup. Especially since my best friend owns a speed shop
Yeah, there have been 2 or 3 failures of blue stripes, but what percentage is that of the total number of blue stripe owners out there? Alot less than 1%. No spring is going to be 100% fail safe, because if there was one, it'd put the rest of the manufacturers out of business.
I have over 25,000 miles on my blue stripes and I don't think twice about them causing me any problems. When I eventually take these out, I'll replace them w/ another set.
#32
#33
The one other thought I'll add to the subject is that aggressive ramp rates will have an impact on spring life and pushing the envelope of the advertised lift. I would have gone with a bigger spring on something like an XER, but feel safe running just under the advertised with an XE grind.
