VHP heads
Old Sep 9, 2004 | 06:43 PM
mrr23's Avatar
ok port specs for you guys
intake 224cc
exhaust 80cc
chamber 63cc
Old Sep 9, 2004 | 08:49 PM
marc_w's Avatar
Originally Posted by mrr23
i'm hoping on 30-40hp throughout the range. but, we'll see. they took the 047 out and installed the 055. it softened the low end enough to help hook and brought the top end up more. on 18" drag radials in the heat, the car is almost in the 11 sec range.
That's sweet.
Yeah, when I was on the phone with them, Roger said he pulled the 047 for the 055 - if I remember right, he lost a little in the 60'(?) but gained at the full quarter. (He used that a reference to the low end power I was looking for). Maybe it was 0-60 he said... it's fuzzy right now.
I believe he actually said the car was in 11's now with slicks? I know he wanted to keep it all street oriented, which is why he probably isn't advertising the slick times.
Old Sep 9, 2004 | 09:35 PM
mrr23's Avatar
i don't know if he's actually ran with slicks yet. he may have said with slicks it's in the 11s. here's the last posted results which is the 055 cam. because of having less intial torque, the 60ft has gotten better. and helped the top end vs the 047 cam. http://www.vincihighperformance.com/...ARPARENT2.HTML
Old Sep 22, 2004 | 12:25 PM
marc_w's Avatar
Right - I think that's what he said about the 047 vs 055. I'll never have traction issues with my truck, so the 047 is working out great for me.
Old Nov 13, 2004 | 09:06 PM
mrr23's Avatar
update. heads should be going on next weekend.
Old Jan 13, 2005 | 10:51 PM
mrr23's Avatar
well, took the heads off tonight. was easier than i thought it would be. took my friend nate and me 2.5 hours to get them completely off. i have pics. will put them up eventually. hopefully i can get the heads on tomorrow night.
Old Jan 13, 2005 | 10:58 PM
jrp's Avatar
jrp
SN95 Director
when are we going to get the results? and did you ever get the port volumes?
Old Jan 14, 2005 | 01:11 AM
Bo White's Avatar
Those are some nice ports.....and a old thread lol.
Old Jan 14, 2005 | 07:09 AM
mrr23's Avatar
in post #21 i put the port volumes up. maybe you meant flow numbers? one of these days i'll get the flow numbers and put them up.
intake 224cc
exhaust 80cc
chamber 63cc
today is putting the springs on the new heads, clean up the block and start putting it together. i did rebaseline the car before teardown. that way it's current numbers. wednesday i went to the track and got baseline times again.
Old Jan 14, 2005 | 07:10 AM
mrr23's Avatar
yes it is. the heads were supposed to go on back in november. but, the 00 formy crapped the tranny. so, that came first.
Old Jan 14, 2005 | 08:27 PM
mrr23's Avatar
finished today. took about 5 hours to install everything and start it. so, total time in the 10 hour range. pics of the install up later tonight.
Old Jan 14, 2005 | 09:14 PM
  #32
Bo White's Avatar
Sorry bout the tranny woes, did you upgrade while you were at it? Them heads will put more strain on it !!
Old Jan 14, 2005 | 09:33 PM
  #33
mrr23's Avatar
i have 2 formulas. the tranny was for the 00 black formy. the heads went on the 99 white formula.
Old Jan 15, 2005 | 03:50 PM
  #34
mrr23's Avatar
ok pics of the head install up here: http://www.stealthram.com/1999pontiacformula.html then click VHP head install.
Old Jan 15, 2005 | 03:54 PM
  #35
Sport Side's Avatar
You sure do like pink
Are the flow numbers on the site?
Old Jan 15, 2005 | 03:55 PM
  #36
mrr23's Avatar
yes she does. and no they aren't. trying to find my sheet.
Old Jan 21, 2005 | 06:28 AM
  #37
CoolSSBoy's Avatar
Any dyno results or track times? The heads have been on for a week now and quite a few folks are curious. A lot of pre install talk and then nothing. Hopefully we will get a good comparison with heads only, heads and cam and then the heads,cam and nitrous. Would be a nice progression. Thanks.
AJ
Old Jan 21, 2005 | 03:47 PM
  #38
mrr23's Avatar
track times i have as of 1/19/04. after dynos not yet. i have my flow sheet finally. i'm reluctant to post the results after what happened in the AFR VINCI thread. one thing to note on my heads. these are my 4.8L heads i had them port. vinci only likes to use 5.7L heads. i will post up flow chart shortly.
track testing - i went to the track on 1/12/05 to get current times. best was 13.144 @ 105.63 and 13.144 @ 105.67. best run on 1/19/05 was 12.918 @ 107.55 with not tune. i've been driving around with a scanner looking at knock retard and o2s. i'm getting about 3.5* knock retard in the 4000 range and running a little lean by looking at the o2s.
i'm also dealing with a right bank low cat efficiency that started on the 1/12/05 track night. the car has bested a 11.84 @ 121.16 on 175 n2o. on 1/12/05 it went 12.04 @ 113.26 no nitrous runs were made on 1/19/05. went to do a run and the main power toggle switch broke. didn't know until i went to engage the nitrous during the run. but, with the knock retard of 3.5*, it may have been a good thing.
after dyno results when i can make some time to get it on the dyno. oh and as far as the dyno numbers go, i put the car on 2 dynos the same day for comparisons. i used macedo motorsports dynojet 224e that uses WINPEP7 at about 3:30pm (he has dynoed 1000hp vipers on it). then went straight to vinci's dynojet 248e that is DOS based and inground and made runs at about 4:30pm. the WINPEP7 showed 307 rwhp and 313 rwhp. vinci's showed 327 and 333 rwhp.
i will do my best to get all slips and graphs scanned and put up tonight.
Old Jan 22, 2005 | 04:21 PM
  #39
mrr23's Avatar
Default flow chart
ok here's the flow chart for my 4.8L head that vinci ported for me.
Old Jan 22, 2005 | 04:27 PM
  #40
mrr23's Avatar
now here's where i rebaselined the car on jan 13th vs april 04 just to see if there were any differences. runs were made when engine temps were at 185* according to scanner readings.
ACTUAL
SAE
By Brett Foote | 2026-06-04 05:00:17
