VHP heads
Old Jan 22, 2005 | 04:41 PM
  #41
mrr23's Avatar
now these are the graphs from macedo motorsports. runs were made when engine temps were at 185* according to scanner readings.
ACTUAL
SAE
Old Jan 22, 2005 | 04:45 PM
  #42
mrr23's Avatar
now. test parameters are changing. because of the right cat coming apart, i will be hollowing the hi-flow cats out and adding o2 simms. will go back to track for more runs before tuning. at least we can see how much more i can gain by 'removing' cats.
Old Jan 22, 2005 | 05:03 PM
  #43
mrr23's Avatar
and the timeslips
NA before heads
175 N2O before heads
NA after heads no tuning
Old Jan 24, 2005 | 11:48 AM
  #44
marc_w's Avatar
Wow... nearly 8mph?!
Nice...
Old Jan 24, 2005 | 06:50 PM
  #45
mrr23's Avatar
marc w - the 8 mph is a loss from the last time i was out. right side cat came apart internally. i have pics of it.
on the heads alone, i gained .2 and 2 mph with a bad cat (not apart but throwing code)and no tuning. cats are hollowed out now and o2 simms in place. going back wednesday for more times before tuning. i might try to play with the VHP tuner while i'm there.
Old Jan 24, 2005 | 08:31 PM
  #46
marc_w's Avatar
Awe geeze... The 8mph thing is a reading comprehension problem of mine. Even with the bright pink outlines - I still read the times off of the left lane on those Before/After - no juice runs... Sorry for the confusion there.
Either way, good stuff. That car's still on the stock cam, right?
Old Jan 24, 2005 | 08:35 PM
  #47
mrr23's Avatar
yep stock cam. vhp waits until last to put a cam in. unless the customer wants it. get the most power without sacrificing driveability and idle quality. the heads just finished up stage IV of the series. stage V is the cam.
Old Jan 25, 2005 | 07:43 PM
  #48
mrr23's Avatar
ok cats hollowed and o2 simms in place. going to track tomorrow night.
Old Jan 28, 2005 | 08:44 PM
  #49
mrr23's Avatar
ok results are in:
distance-----NA ----- N2O
60ft ------ 1.930 --- 1.881
330ft ----- 5.460 --- 5.005
1/8 ------- 8.286 --- 7.559
mph ------ 87.32 --- 95.58
1000ft --- 10.743 -- 9.786
1/4 ------ 12.822 -- 11.671
mph ----- 108.59 -- 119.60
in comparing it with the beginning runs before heads with cats to now 4.8 ported heads and no cats it's:
NA .322 and 2.92 mph
N2O .378 and 6.34 mph
i'm going to discount the mph gain on the bottle. i had issues with the right cat when i did the before heads n2o run. i got the SES light during that run. so it was the beginning of the end right there. i've done 117 mph in the past at OSW. still no tune. but, next on the list.
Old Jan 28, 2005 | 08:50 PM
  #50
jrp's Avatar
jrp
SN95 Director
so, .3 and 3mph from the head swap, stock cam, and no tune?
Old Jan 28, 2005 | 08:52 PM
  #51
mrr23's Avatar
yes. head swap included using the mrg gasket .042" gasket. so it raised compression as well. just a reminder on that.
Old Jan 28, 2005 | 08:56 PM
  #52
jrp's Avatar
jrp
SN95 Director
rest of the mod list? its confusing following all the different **** you do and what mods are on what car, lol.
this was just and R&D type of thing right?
Old Jan 28, 2005 | 08:58 PM
  #53
mrr23's Avatar
from the other thread
99 pontiac formula
automatic
stock converter
3.23 gears
stock ls1 intake
stock ls1 cam
VHP airlid
VHP air filter
VHP MAF ends
VHP/Crane 1.89 accelerated lift rocker kit
VHP/Crane dual valve springs
bassani 1 5/8" optimum length headers w/hi-flow catted y-pipe
borla catback
CHANGING
VHP ported 4.8L heads
no cats
mr gasket .042" head gasket
Old Jan 28, 2005 | 09:01 PM
  #54
jrp's Avatar
jrp
SN95 Director
not bad. now throw a cam in that bitch
Old Jan 28, 2005 | 09:02 PM
  #55
mrr23's Avatar
that's funny. i was just typing the mods list when you posted this. R&D meaning that VHP only ported the 4.8L just for me? or i'm just trying to continue my PRODUCT PIMPNESS? today vinci added my flow chart to their page. he's considering selling them as 'street' heads. but like i said before, i test every little part i put on my cars. i like to know what that part does all by itself. unfortunately, the cat decided to interfere with the proceedings. i don't do a heads and cam and wonder which one did what.
Old Jan 28, 2005 | 09:05 PM
  #56
mrr23's Avatar
a cam is the final step for the motor. but, my 00 formy wants attention now. so a YANK SS3400E is what i want to put in it this time around. with 2 cars, i can do both ways. the expensive way (99 formy) and the cheap way (00 formy). i'm shooting for high 10s in the 00 formy. 11.81 @ 121 so far with only a SLP airlid, K/N filter, bassani dual exhaust and 200 n2o. mph is there. just need to get it to jump out of the hole now.
Old Jan 28, 2005 | 09:07 PM
  #57
jrp's Avatar
jrp
SN95 Director
i meant R&D just as that, because obviously you could do installed some LT, ORY, and tune and netted the same gains. im just trying to put the thread into context before people try and bash the results.
despite as much VHP pimping you do, the tests and results are always very interesting, keep it up
Old Jan 28, 2005 | 09:11 PM
  #58
mrr23's Avatar
yes it was just for R&D purposes. car already has headers and now technically an ORY-. unfortunately for the wife, it's now too loud for her. i might be putting the bassani tru-dual on her car to quiet it down. now that'd be a neat test. borla w/small open plate vs bassani tru-dual. another thing i've seen wanted on this board. a single to dual test. HMMMMMMM
Old Feb 15, 2005 | 06:57 PM
  #59
mrr23's Avatar
ok finally go it back on the dyno. first one is heads, no cats, untuned. second is untuned vs tuned using the VHP handheld tuner. as the notes say, i ended up using CAM #3 +10% power enrichment so, a total of 34 rwhp and 29 rwtq peaks.
