new cam with out tune?
What would be a suggestion for wanting to have the cam installed locally but then taking it to a tuner about 2 hours away?
as far as the crane cam spring kit and hte comp cam spring kit wich ones are better.
and would the cam gaskets be essential.
As far as springs, get what Thunder recommends, or the Patriot Gold's like I put in. The Patriot Gold's are awesome, and no shimming needed. You can get a cam swap gasket kit from Thunder too, but they aren't "cam gaskets" per say, stuff like water pump, timing cover, etc.
Do your research on this, b/c you should do the ported LS6 oil pump, a new timing chain (double roller if possible), maybe a pulley and some other stuff if you want, now is the time to do that stuff.
what they said. you'll be fine for a couple of hours. I would recommend either the Patriot's or the Comp's for springs. I broke a couple of Crane dual's not too long ago.
