Is it a must to take off A/C radiator for Cam install
Old 09-01-2004, 07:47 PM
King02SS's Avatar
Originally Posted by koniu77
you guys have A/C in your cars????
Wurd! I didn't have to disscharge it for mine either on my first cam swap. Like they said just have someone hold it out of the way. Good luck on the swap.
Old 09-01-2004, 09:10 PM
ProStreet_632's Avatar
Default Cam Install
Best advice, put the car on jack stands, drain the radiator, unhook all the wires going to the fan pull the fans out from underneath the car and then pull the radiator out of the top. The A/c condensor will still be hooked up, but you can lift it up and drop it to the ground, and it will be out of the way and you can do it by yourself.
