Is it a must to take off A/C radiator for Cam install
Since when? I had my motor out for 11 months... A/C went in with no problems, again for another 6 months and again no problems.....
Did you know that you should replace the dryer once a year even if it's not opened up ?? Since your system was opened up and the dryer was not replaced right now you have an AC system that's full of moisture that's forming acid that's eating away at the metals from the inside out. By the time you know it has a problem you can get your wallet out to fix it. When you open the system up moisture gets in. There's no way around this. Moisture + the oil that's in AC systems makes acid.
Believe me I deal with this literally every week.
Note: I had a friend helping...but I knew better than to just have him hold it...LOL.
