T-REX with GTP stage 2LS1 heads? unmilled
i was thinking about a t-rex (not going to be much of a daily driver car anyways) but i have a set of GTP stage 2 LS1 heads unmilled BUT with Ferrea 2.02/1.60 valves. am i going to have clearance issues with those valves even with stock size chambers? if so what should i change about the cam to make it work with them? LIFT?DURATION?LSA? i have no idea so any info would kick ***.
Originally Posted by Zapata
any suggestion on how much to alter each to make it work?
Originally Posted by Beast96Z
The T-rex was designed for max power with stock heads. From the graphs I have seen, it dosen't perform as well with ported heads.
Originally Posted by MyLS1Hauls
Not true. Big cams work great with big heads...and the Trex is no exception. It wasnt necessarily designed for stock heads...it was designed to fit with stock heads and not have to notch pistons.
Thanks Brad you are correct. I don't know where people get to thinking this cam is not designed to make good power with ported heads. It was designed around stock heads at first for P/V reasons.
My first outing was in 4000+ DA so I don't really want to comment on the times
Originally Posted by Fireball
I'll see if I can give you some ET proof tonight...
the car is street/strip...but is a th400 setup with 3.42 rear gears and a 4,000 stall....i might just stick with the stock heads until i build a motor to work with an even bigger cam. T-REX with stock heads is very impressive as it is.
