New Cure For Stock Rocker Spilt Bearings
I just felt this thread was not gettting enough hits.
Please give your thoughts and feedback.
This would be a cure for the bearing issues, also will help with a lot of clearance issues with aftermarket rockers.
https://ls1tech.com/forums/generation-iii-internal-engine/211917-modified-ls1-rocker-arms-new-bearings.html
Well like I posted in another thread, had I not just invested in a set of YT 1.7's I'd be all over this like white on rice. This is a great idea. I just hope it doesn't turn out like the two piece timing cover If the price is right, I might consider postponing the install of my YT's and see how these go and pick up a set. You can get stock rocker arms CHEAP and swap those out with Nasty if his original idea holds up. I'm definitely going to stay tuned.
