Castrol Syntec?
Old Sep 6, 2004 | 09:28 PM
Gonzo1's Avatar
Default Castrol Syntec?
What weight of oil goes in a 2000 SS that came from the factory with the Castrol Syntec option? 10w-30 10w-40 5w-30? If not one of these which one? Also this is synthetic correct?
Old Sep 6, 2004 | 11:52 PM
SSDude's Avatar
The SS came from the factory with Mobil 1 5w-30. However, German Castrol 0w-30 is a better oil. Used oil analysis shows less engine wear when it is used.
Old Sep 6, 2004 | 11:57 PM
Hot02SS's Avatar
Ive been using Mobil 1 5w-30 sense I got the car. Synthetic is the only way to go.
Old Sep 7, 2004 | 06:24 AM
max's dad's Avatar
The SS came with Syntec in 99 and 2000 as an SLP option. It was 5-30. The "German" Syntec is the best product. It's an 0-30, and can be found at Auto Zone.
Old Sep 7, 2004 | 04:18 PM
Bill's 02 Z-28 SS's Avatar
Hi Folks
I maybe using the wrong oil but I have been using Castrol Syntec 15-50 - racing oil.
Bill
Old Sep 7, 2004 | 04:49 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Originally Posted by Bill's 02 Z-28 SS
Hi Folks
Bill
Were you ever told to use this? Sounds awfully heavy for a stock motor...I could see a racing engine using this that doesn't have the tight tolerances, but not a standard ol' LS1.
Old Sep 8, 2004 | 11:57 AM
Hi Folks
NO one ever told me - I looked at the OIL - it is for racing and the car is only used once in awhile - pushed hard. The car has an LS6 modified oil pump and I did not think it would hurt but maybe I better rethink it.
Thanks
Bill
Old Sep 8, 2004 | 01:07 PM
Casper9T9's Avatar
Hi Folks
Thanks
Bill
You would probably loose power with that weight oil. Stick to a 30 weight.
Old Sep 8, 2004 | 01:23 PM
PHANTA-Z's Avatar
Ive been running Sytech 10-30 since the second oil change (first one was with "dyno" oil for break-in purposes). Have had 0 issues or oil burning. I definitly reccomend it.
Old Sep 11, 2004 | 08:24 PM
Gonzo1's Avatar
What is different about the German Castrol 0w-30? How does it differ from the Castrol 5w-30? Which would be better wheather wise since I live in Tennessee?
Old Sep 12, 2004 | 12:26 AM
SSDude's Avatar
The Castro 5w-30 is hydrocracked dino oil. In other words it is not a true synthetic. It is Group III oil. The German Syntec is sold as Castrol SLX in Europe and it is a Group IV (PAO)/Group V (Ester) blend. It is a true synthetic. The bottom line is that you will get lower wear from using German Castrol as confirmed by oil analysis.
