918's with XE-R lobes?
Old Sep 7, 2004 | 04:11 PM
Greg Fell's Avatar
Default 918's with XE-R lobes?
My homie wantin to put in my old cam. He has stock retainers, and 918's on a stock ls1 head/motor.
cam is
Comp Cam XE-R
232/236 .595/.601 @ 112
Will the 918's hold up to these aggressive lobes?
Old Sep 7, 2004 | 04:15 PM
ohhiitznik's Avatar
No, they are rated for 600 lift, that one is 601. So I def would go with dual springs.
Old Sep 7, 2004 | 04:35 PM
94form2000z's Avatar
I've heard of them used for cams of around that size...BUT I wouldn't go there. Duals are to cheap to not use them.
Old Sep 7, 2004 | 04:39 PM
next's Avatar
I'm usually fine with running near or at recommended lifts, but NOT with an XER grind. Go dual.
Old Sep 7, 2004 | 04:59 PM
JoeDirt's Avatar
Too risky at that lift with the xer
Old Sep 7, 2004 | 05:00 PM
cyphur's Avatar
too extreme a lobe profile. if you like to kiss your pistons, run that for about 15k miles....if you get that far
many ppl have had good luck with 918's. i wouldn't risk it. go duals...either crane, or even better, patriot golds.
Old Sep 7, 2004 | 06:37 PM
MyLS1Hauls's Avatar
Remember, Comp used to rate the 918s at .625" max lift, but lowered it to .600 once their 921 Duals came out...hmmm...
Old Sep 7, 2004 | 06:39 PM
cyphur's Avatar
i had forgotten about that....
Old Sep 7, 2004 | 06:45 PM
MyLS1Hauls's Avatar
Check this out Note the lift and rpm specs.
Old Sep 8, 2004 | 12:11 AM
Ferocity02's Avatar
I use 918's with my XE-R, but the lift isn't nearly that high. With that cam, I'd get some duals for sure.
