Ordering Valve Seals?
Old Sep 9, 2004 | 04:14 PM
bletour2001's Avatar
Default Ordering Valve Seals?
Hey Guys,
So I am going to do a valve spring swap and want to buy new valve seals. I found GM part #s for both intake and exhaust but I am not sure if that is for a set (gmpartsdirect lists it as a seal kit) or single seal. (i.e. do I need to order 1 or 8?) Anyone order GM valve seal kits?
Old Sep 9, 2004 | 04:22 PM
crainholio's Avatar
When I bought my GM seals, the part#s were different for intake vs. exhaust and the seal material colors were also different (brown vs. black).
The part#s are on here somewhere if you search, I had the dealer look them up (1998 Z28) and the numbers matched.
Old Sep 9, 2004 | 04:28 PM
2xLS1's Avatar
Are you going to be using single or double springs?
Old Sep 9, 2004 | 04:46 PM
Hysteria's Avatar
I have some in my hands, the tan ones are #12482062 and the black ones are # 12482063. There are eight in each.
Old Sep 10, 2004 | 08:47 AM
Doubles.. Cranes.
Why does that effect the seals used?
--Bill
Old Sep 10, 2004 | 09:26 AM
Hmmm those are different than the numbers on LS1howto for an Fbody spring swap... Brown 12457652 Black 12533586. Gmparts direct lists all of them as valve seal kit. Does the F-Body have different seals than the C5?
Thanks,
--Bill
Old Sep 10, 2004 | 09:32 AM
Hysteria's Avatar
Those part numbers are the ones I use on my heads and are the direct replacement for the 2002 Pontiac firebird. These I use because they have the spring cup made on them so they may not work in your application because of the dual spring set up you have.
Old Sep 10, 2004 | 10:10 AM
2xLS1's Avatar
Originally Posted by bletour2001
Doubles.. Cranes.
--Bill
You can't use the 02 and up one piece spring seat/seal with doubles. You need to use the 97-01 seals. The are sold in packages of 8.
In - 12533586
Ex - 12457652
Old Sep 10, 2004 | 10:24 AM
In - 12533586
Ex - 12457652
THANKS 2xLS1!!
--Bill
