Comp R lifter failure?
Old Sep 9, 2004 | 06:40 PM
H82BBad's Avatar
Default Comp R lifter failure?
anyone had comp r lifter failure yet? We had preload set perfect. I pulled engine due to oil pressure problem. (It started losing oil pressure WOT) When I pulled the heads we noticed 3 of the lifters the cups were not clipped in any more.Like the clip had come out.
Old Sep 9, 2004 | 06:41 PM
H82BBad's Avatar
BTW these are comp r's with less than 3000 miles on them
Old Sep 9, 2004 | 06:47 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Did they make any noises?
H82BBad's Avatar
yeah they have
I have always had some valve train noise Have went over the lash more than once. Heck I have had it double and triple checked by others also. So the lash was not the problem.
Old Sep 9, 2004 | 07:09 PM
LS1Tech Co-Founder
How loud?
Old Sep 9, 2004 | 07:14 PM
crainholio's Avatar
Yup, I had one Comp-R fail on me in similar manner. Mine made no noise, I just found the two broken pieces of the stamped-steel plunger retainer stuck to my oil pan magnet while doing a routine oil change.
Comp Cams was very cool about it, swapped the entire set on warranty even though only one had failed.
They were easy to swap in my old L98 engine, no head pulling required.
Old Sep 9, 2004 | 07:36 PM
taqwache's Avatar
crain, could you take a pic of those pieces you found in the oil. i think i have the same problem and found a piece of a plug in the oil also. well atleast i think i did since the drain plug fell into a dirty drain bucket before i checked it. its possible it picked it up from there.
Old Sep 9, 2004 | 07:46 PM
crainholio's Avatar
Can't help unfortunately, I sent the pieces and the 16 lifters back to Comp in exchange for the new set.
The two pieces were roughly U-shaped, stamped steel.
Old Sep 9, 2004 | 08:48 PM
H82BBad's Avatar
I will take a pic as soon as I can. I also found a piece of metal on my oil drain
Old Sep 9, 2004 | 08:49 PM
H82BBad's Avatar
How loud?
mine made more noise when cold and it got softer as the car warmed up
Old Sep 9, 2004 | 11:23 PM
taqwache's Avatar
thats cool. thats not what i found anyways. this piece was a little circle with a concave side and about 1/4 inch diamater. for the life of me, i could not see where it could come from. i even took apart one of my stock lifters and did not see anything like it on there. the heads are comeing off soon anyways so i will check them all then.
Old Sep 9, 2004 | 11:24 PM
taqwache's Avatar
sounds good let me know. i hope am just going crazy .
Old Sep 9, 2004 | 11:46 PM
Steve Burger's Avatar
LS1TECH Sponsor
I would like to see a picture as well. I found a single U shaped peice of metal on the drain plug. Car seem to run fine but this is nagging at me. I have 977 springs and Comp R lifters. I am half tempted to dump th lifters and springs this winter for peice of mind.
Old Sep 10, 2004 | 06:34 AM
SAM98WS6's Avatar
im sure by preload set perfect you mean .008-.010 past zero lash right?
Old Sep 10, 2004 | 10:42 AM
H82BBad's Avatar
by the time mine made it to the drainplug it was a very small cicle also. maybe 1/3 the diameter of an eraser
Old Sep 10, 2004 | 10:43 AM
H82BBad's Avatar
we had .005 to .010 on all of them
Old Sep 10, 2004 | 11:41 AM
SAM98WS6's Avatar
wow. just curious what rockers now.
Old Sep 12, 2004 | 09:11 PM
taqwache's Avatar
uh oh. thats sounds like it. well the heads are comeing off the week so i will let yall know what i find.
Old Sep 12, 2004 | 09:24 PM
Greg Fell's Avatar
I had a set fail.
