surging when put in gear
Old Sep 10, 2004 | 11:56 AM
blu98ta's Avatar
Default surging when put in gear
Sorry if this is in the wrong forum. If it is can somebody move it for me. I have recently had my cam installed and the dyno tuine from hpe. I drilled the hole out in the throttle body one size bigger before I had it tuned. Since it has been tuned the car will sometimes surge a couple times and then die when I put it into reverse or drive. Should I drill out the hole one size bigger? If i do that will it raise my idle? I like the way the car idles now, but I don't like the fact that it likes to die when I put it into gear. What should I do?
Old Sep 10, 2004 | 12:16 PM
MyLS1Hauls's Avatar
You'll need more custom tuning. With a cam that small, you dont even have to touch the TB hole. Who did your tuning originally?
Old Sep 10, 2004 | 12:34 PM
Boostaholic's Avatar
I run a much bigger cam and have surging problems when my throttle is closed and its in gear, long as the throttle is at least part way open it seems fine though.
Old Sep 11, 2004 | 01:09 AM
blu98ta's Avatar
HPE. And by the way it was a great tune. I got exactly the power I wanted out of it, if not more. And by the way, I don't care what car it is, a bigger cam is going to want more air because it is adding more fuel. If not, then it wouldn't add any performance gain. Bigger cam=more gas. More gas needs more oxygen or else it runs rich, and that is not good.
Old Sep 11, 2004 | 01:10 AM
blu98ta's Avatar
I don't want to have to do that. I have been experimenting with that all day, and it seems to work. I don't want to have to do that thoug. I'd rather just be able to throw it into gear and go. I would expect a little hesitation, but not a stall. What should I do??
Old Sep 11, 2004 | 01:14 AM
MyLS1Hauls's Avatar
Originally Posted by blu98ta
HPE. And by the way it was a great tune. I got exactly the power I wanted out of it, if not more. And by the way, I don't care what car it is, a bigger cam i going to want more air because it is adding more fuel. If not, then it wouldn't add any performance gain. Bigger cam=more gas. More gas needs more oxygen or else it runs rich, and that is not good.
Whats that mean exactly? A bigger cam doesnt add more fuel itself. Its actually the opposite...it allows more airflow and therefore requires more fuel to be added. I never said you didnt gain the power you wanted...we're talking about idle quality here, so take it easy. Trust me, you dont need to drill the TB for a TR224... I think its funny when newbs come on here and ask questions and then insult those who take the time to answer their questions
Old Sep 11, 2004 | 02:43 AM
blu98ta's Avatar
Well then my question is "what causes the surging?" and how can I fix it? Everyone that I have talked to has said that I was going to have to drill out th tb. you are the only one that has told me otherwise.
Old Sep 11, 2004 | 11:14 AM
Mooobunnny's Avatar
Are you still running a stock converter? A higher stall should fix the problem
Old Sep 11, 2004 | 02:22 PM
blu98ta's Avatar
ya I'm still running the stock converter. So changing to that vig 3200 should fix it? Thanks for all the help!
