5.3l
Old Sep 10, 2004 | 09:06 PM
un4giv3n's Avatar
Default 5.3l
is the 5.3l engine out of the silverado aluminum? is it possible to put 6.0l heads on a 5.3l to drop the compression for f/i? is the block/internals as good as the 5.7l as far as durability goes?
Old Sep 10, 2004 | 09:52 PM
Hysteria's Avatar
The 5.3 is iron block/aluminum heads. Has the same crank/rods in it as 5.7 and 6.0 crank. The 4.8 has the same block as the 5.3 just a shorter stroke crank.
Old Sep 10, 2004 | 09:53 PM
blue by you's Avatar
The block in an SSR is aluminum, but the ones in the trucks are iron.
Old Sep 10, 2004 | 10:02 PM
Hysteria's Avatar
Interesting, did not know that. Speaking of the shorter stroke 4.8 crank, dont mean to hijack, be a great cheap rpm engine with that crank/rod in a 6.0 block/pistons. BTW, the rods are also longer in the 4.8 to take up the difference in the crank stroke.
Old Sep 11, 2004 | 12:15 AM
un4giv3n's Avatar
thanks for the replies. so would it be a good FI engine?? with 6.0 heads i guesstimate it would give a 8.5-9.0:1 compression? can these blocks be bored over to 5.7l? I understand that more cubes=more power but 5.3s and 4.8s are dirt cheap. the wiring harness, is the same for these motors right? you could take an ls1 long block and and interchange it with the 5.3?
